Old 10-08-2006, 04:27 PM
Malibuskier Malibuskier is offline
Heater hose help....
I am looking for the part number for the heater hose that attaches to the intake manifold. Mine is leaking where the hose clips into the fitting on the intake manifold. Anyone know what it is?
Dave
Old 10-08-2006, 07:49 PM
LastOne LastOne is offline
Re: Heater hose help....
Go to your local parts house and get a new nipple that will screw in place of that POS coupler GM came up with. Then get a new piece of regular heater hose and you are done. I did mine 3 years ago with no problems
Old 10-08-2006, 10:04 PM
67malibu 67malibu is offline
Be careful. If that sucker is even a little corroded, it will break off rather than screw out of the intake. I think the General made them out of pot metal. I ended up having to rethread the intake for a NPT nipple fitting, but mine had corroded alot more than appeared from the outside.
Old 10-12-2006, 01:56 PM
oldchevy oldchevy is offline
yes, i replaced mine about 6 months ago for the same problem. It is pot metal and if it breaks you will have a problem on your hands. Just use some liquid wrench type of products and go slow. The part is about $10. It has the plastic clip, washer and metal housing. The hose does not come with it. It is most likely the o-ring washing inside the housing. No part number since you do not mention what type of vheical. Get the part from a dealer.
Old 10-12-2006, 02:08 PM
alblogg's Avatar
alblogg alblogg is offline
Yep that works better and is a whole lot cheaper than buying the replacement part from GM that was not to great in the first place in my opinion and is easier to get off to back flush your heater core.
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'98 Pontiac Grand Prix GT, 3.8
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
