Old 10-08-2006, 01:21 PM
86CameroRs 86CameroRs is offline
2.8 V6 rocker arm torque specs, please help.
I'm almost done doing a top end rebuild of the 2.8 in my camaro and don't know what to set the rocker arm torque at, the motor has the origional hydraulic cam and has multi port injection. Please help!!!
yes yes I know i spelt Camaro wrong when I set up my Screen name, but i dont know how to fix it.
Old 10-08-2006, 01:35 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: 2.8 V6 rocker arm torque specs, please help.
just so you know, it's "Camaro".
Seatbelts Saved My Life
Old 10-10-2006, 09:42 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
86,
I'll wee what we con do to get your name fixed before the the heard gets in a ruckus.
Question, have you spec'd the cam to make sure it's still holding up?
As for the rockers, a specific torque spec would be in a service manual (35-30 ft lbs sitcks in my head from my 3.8 buick), not sure about the 6ers but on the SBC 305 and 350s we would just get em bottomed out snug , then go 1/2 round on all then 1/4 round.
Old 10-10-2006, 07:56 PM
88camaroproject's Avatar
88camaroproject 88camaroproject is offline
Send a message via AIM to 88camaroproject
make sure the intake manifold gaskets are on before you put the rockers and rods in cause the ones that say not to cut cant be put on when all that is on...and the chiltons book says what it is. its not a torque. you get the lifter down and tighten the rocker till theres no up and down play in the rod then go i think half a turn?? not sure on that, actually i will go look it up in my chilton...... ok when the motor is at top dead center you can work on exhaust valves 1,2 and 3 and intake valves 1,5,and 6. tighten the nuts till there is no lash but its not pushing down on the rod. you shold not be able to move it up and down but you can spin it. then tighten the nut an additional one and a half turns. so 720 degrees. then rotate the crank one full revolution so its back at the zero degree timing mark. now you can do the same to exhaust valves 4,5,and 6 and intake valves 2,3,and 4
87 firebird formula ws6
(currently has a old 78 305 with the following upgrades,
including lots of miles and stock heads and internals....oops)
crane cam cam specs
performance valve springs and retainers, flowtech headers, 255 lph fuel pump,
holley 600cfm carb, weiand single plane manifold, a healty diet.
14.90 1/4 mile....just wait for the 406 to be finished
MY VIDEOS
MY PICTURES
-Tom
Old 10-10-2006, 08:01 PM
oh and for the record chiltons says 1 turn after no lash for the 5.7
crane cam cam specs
MY VIDEOS
MY PICTURES
-Tom
