Old 10-07-2006, 06:42 PM
jayhill jayhill is offline
Re: How difficult is to replace ECM?
I have a 92 LaSabra, Does Anyone know where the ECM is on It?
I Have a simalar Problem. Alt. only Charges Part Time. New Alt. did not fix the Problem. Help!
Jay Hill
I Have also Had Good Luck With NAPA Lifetime Warrenty Alternaters and Starters.
Old 10-08-2006, 01:23 AM
spinne1 spinne1 is offline
Jay Hill
You would much better luck starting a new post, but anyhow, it is located under the dash on the passenger side and can be seen by removing the large black plastic shield under the dash on the passenger side and then by removing a 10mm nut and bracket, at which time the silver rectangular box (the computer) can be pulled down and disconnected from its three wiring harnesses.
Old 10-08-2006, 03:35 PM
Bassasasin Bassasasin is offline
Alternator charges part time?.. voltage drops?
What?
Why do you say that?... battery dies?..
Bad connections at the battery?
Bad battery.. shorts inside?
Lots of stuff without explaining how you come to the conclusion.
If the voltage is 14 v... its charging...
Bass
00' Park Ultra
94' Park Ultra
94' LeSabre
96' LeSabre
