Old 09-04-2002, 08:43 PM
sundiegoboy619 sundiegoboy619 is offline
Lightbulb is it possible for a b20/gsr frankenstein?
would it be possible to slap a gsr head onto a B20 block with a gsr tranny? if so, you should still incure the vtec power or am i wrong!
Old 09-09-2002, 03:25 AM
Sulsa Sulsa is offline
Yes, I've heard of ppl doing that. I think you have to move the studs you mount the head on and install an oil line from the block to the head, but thats typical with the crvtec conversion. Some more precise info if you just search for crvtec at google.
Old 09-09-2002, 07:16 AM
luti luti is offline
Send a message via AIM to luti
Is their a difference between the B16A head and the B18C head?
T3/T04E turbocharged ricer.
Old 09-09-2002, 01:44 PM
Yes, but very similar. Here is a link to a site with some info.
http://www.lightningmotorsports.com/techhonacua.htm
Old 09-09-2002, 09:35 PM
Rice_destroyer Rice_destroyer is offline
i personally wouldn't go with a GSR head just due to fact that if you don't have a GSR ecu, you'll be losing a good 20-30 hp because you'll have no way of opening the dual butterfly intake system that it has. and if you take those out, you'll lose a lot of low end torque and have a shitty take off. i'd recommend the B16 head just because the parts are interchangeble with the CTRs and ITRs and you don't need a GSR ecu.
94 SI, B18B1, port n polished head, SRP 9.2 slugs, Eagle Rods, Total Seal rings, ARP bolts, Nuformz blockguard, MSD ignition, apexi V-AFC(hack), PYR chip(8500 redline), 450cc injectors, bbk f/p, custom T3 kit w/MP equal length manifold, huge intercooler, restrictive 2 1/2' exhaust
next mod: Hondata+GM MAP
Old 09-10-2002, 01:30 AM
the secondary butterfly valves are on the intake manifold, not the head. So if you went with the GSR intake manifold as well, then yes you would want the P72 ECU. The butterfly valves are open by default tho, the ecu actually holds them closed until something like 5000 rpm's. So even if you stuck with your civic ECU, you would just be missing the low end power. None of the other intakes have this feature tho, so I think it's one of the best setup's to go with. Although, I'm kinda new to the whole Honda power scene, so I could be wrong.
Old 09-10-2002, 03:15 AM
actually those butterflies get restrictive once you start making more power and eventually will make you lose power. my buddy had tried both a B18c3(japanese spec gsr) and a B16a2 on his B20 block and he actually was .6 seconds faster with the B16a2 head. it could vary with different motors but this was just what i've witnessed.
Old 09-10-2002, 03:48 AM
I guess I should have been more specific. For racing, the high flow intakes are better because you are keeping your rpm's high. For a daily driver (my car), where you can benefit from a wider power band, I would rather have the dual stage intake.
Rice is right tho, even with the secondaries open, the flow won't be as good as if you had a type R or skunk 2 manifold. I bet your power band will be much smaller tho.
Old 09-14-2002, 12:34 AM
nemesls_2000's Avatar
nemesls_2000 nemesls_2000 is offline
Send a message via AIM to nemesls_2000
The B16 head has a better flow rate than the B18c
Mods:
AEM intake, DC Sports 4-1 header, Tanabe exhaust w/ 2.5" custom piping, ITR exhaust cam, APEXi VAFC, AEM FPR, Warlboro 255l fp, RC 440 injectors, ACT stage 3 clutch, JR Supercharger, Weapon R coilovers, VIS CF vader hood, CF Angel Eye Projector headlights, Black housing corners w/ amber bulbs, "Hybrid" rear emblem, custom rear speaker panels.
Old 09-14-2002, 07:02 PM
h82lose h82lose is offline
Check out Crvtec.com. Great site
Apexi World Sport
16" Motegi MR7 Wheels
Pirelli P7000 Tires
rods and pistons question for b20 YZ125rider21 '88 - '91 Civic | CRX | Wagon | Shuttlee 8 12-30-2003 12:16 PM
best head for b20 djnutinurface Engineering/ Technical 9 07-28-2003 09:57 PM
Where to get oil line for B20/VTEC york2600 Engineering/ Technical 4 06-04-2003 02:37 PM
