440 and 8 1/4" diff
Will the 8 1/4" diff hold up to a 440?
![]() My Grand Am Picture Site _____________________________________________ 2002 Grand Am GT 77 Dodge Power Wagon 2006 Charger SXT 3.5L V-6 2011 Charger RT 5.7L Hemi 2008 CLK350 Convertible |
Re: 440 and 8 1/4" diff
To answer your question, I would be inclined to say "No".
I understand from your previous posts that you have a 1971 Dodge Charger with a factory 318. I assume you have an automatic transmission, as well. You also state you have an 8-1/4 rear end. In the 318 equipped cars of this vintage, Chrysler used the A-904 (light-duty) Torqueflite automatic and the 8-1/4 rear end. Should you decide to swap in a 440 engine, you also need to connect the 440 to an A-727 (heavy-duty) Torqueflite and an 8-3/4 rear end. Otherwise, you will eventually blow up either the tranny or rear end or both and I am not sure which will go first. That's my two cents on this subject.
"This car may be old, but it will still climb Kirker Pass at 110!" 1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible |
It's a 440 still connected to the 727. The reason I asked was because I heard of the posibility of the diff being a 7 1/4". I found a chart for figuring out what diff you got, but it doesn't show me what the 8 3/4" looks like. From what I can see on the chart I have is that the 8 1/4" and Dana 30 have the same bolt battern and same cover design.
![]() Do you know where I can find out what the 8 3/4" looks like, so I can spot one when I need to get it?
The chart you included in your last post shows the bolt patterns for the rear cover plates for various differentials. The reason this chart does not show the bolt pattern for the rear cover plate of an 8-3/4 differential is because there is none! The 8-3/4 differential assembly includes the front cover plate. The front plate and differential assembly pull out of the front of the housing as a complete unit, a completely different design than the rear access plate differentials. This makes the 8-3/4 unique from the other differentials out there and easy to identify with a quick visual.
To spot an 8-3/4 differential, look for one that does not have a rear cover plate, just a round dome moulded in the case. The differential assembly will have bolts in a circle around the front side of the housing.
There is a Dodge truck at the junk yard right now. If it has a Dana 60, should I just get that? That's what my Power Wagon has on the rear. The front is a Dana 44. Although the chart doesn't say the size of what's inside. Do you know what should be in it?
Another question: Since this 440 and tranny are out of an 80 motor home, I keep hearing that the gear ratio is going to be too low of gearing for the car. What's the best solution? Is changing the grear ratio in the diff good enough, or does the tranny need to be swapped for a car version?
![]() My Grand Am Picture Site _____________________________________________ 2002 Grand Am GT 77 Dodge Power Wagon 2006 Charger SXT 3.5L V-6 2011 Charger RT 5.7L Hemi 2008 CLK350 Convertible Last edited by shark2000; 10-09-2006 at 12:08 AM. |
