Old 09-04-2002, 09:09 PM
Arb Arb is offline
89 Civic LX 1.5 DPI, its sluggish, what can i do?
Other than buy a new ride, what can I do to make it drive better? I'm a mechanic in Flagstaff, AZ and I have all of the regular maintainace covered. New plugs, filters and the like. I have a badass 4x4 that with a weber carb, exaust, and a few lifts.... So I'm not new to performance products, just hondas.
i'm thinking of rebuilding the head, but will an exaust help more? The car is totaly stock. everything!!! Just let me know what my options are and when gives the biggest bang for the buck.
Thanks all
Arb out
Old 09-04-2002, 09:26 PM
Bleebdat Bleebdat is offline
Send a message via AIM to Bleebdat Send a message via Yahoo to Bleebdat
Arb welcome, it depends how much you would like to spend. With your current engine there isnt even all that much feasible gain possible. Your best options would be to swap it out for a newer 1.6l engine from the newer civics. On your engine if you have to keep it, intake headers exhaust, then better plug wires, but IMO it wouldnt be worth it.
Old 09-04-2002, 09:37 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
welcome
we really need a better idea what you want. you can convert to MPFI . then add I/H/E (intake/header/exhaust). you will notice a much better response.
do you just want a quick daily driver? you can get a d16z6 (92-95 Si/EX)or d16y8 (96-00 EX). it drops right in. that engine is approx 130 hp sohc vtec
you can also go with a b16 dohc vtec with approx 160 hp. it requires a little more to swap in
are you looking to be in a certain 1/4 mi. second range?
ami
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 09-05-2002, 10:49 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
I have a 91 Civic Dx, with 1.5l in it. It was sluggish for a long time, but now it actually has some take off to it. All I did too it was get a new exhaust, new intake, put some Accel spark plug wires, Botch Platinum Plus 4 spark plugs, and then reprogrammed the ECU. So far all that helped it right now, and still lets me do an engine swap later without wasting money on this engine. But if your not in that big of a hurry on getting this running, I would either switch it to MPFI, or just do an engine swap. Most of the swaps are pretty easy I think.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 09-05-2002, 11:39 AM
Arb Arb is offline
Thank you all for the warm welcome.
Where and how can i go about getting one of these splendid engines ?
I read that link and bookmarked it.
I didn't catch if i needed the tranny or the block for the 1.6L
Is it just a head swap or do i need the block also?
Do I need a new tranny?
Thanks all
Arb out
Old 09-05-2002, 11:43 AM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
I got I/E, I should do the wires and plugs also.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Tony's Avatar
TLD Member #1
For the swap on the MPFI you just need the head, don't need the block. There are a lot of places that tell how to do it. I don't know if www.sportcompactcarweb.com has it on their site, but I know they have done it cause I have their mags that show how to wire it all it up. I'm sure LadyNRedSi would know where to find out how to do that swap.
Tony
Old 09-05-2002, 11:46 AM
Tony's Avatar
TLD Member #1
Man those spark plugs are great. I just tried them last week, and so far they are the best spark plugs I've had. They cost about $6 each, but well worth it. Good thing I only have to get 4.
Tony
Old 09-05-2002, 11:48 AM
amy@af's Avatar
which 1.6? the sohc vtec or dohc vtec?
you need to swap the whole thing. those head swaps are shady.
sohc vtec all you need is engine, p28 ECU ($150), and a wiring harness ($150). if you have a DX it is ideal to get an 88-91 Si tranny. it is not required but, it has better gearing and you might as well do it while the engine is out.
if you were asking about the b16...check out this link
Old 09-05-2002, 12:07 PM
Arb Arb is offline
Just to recap....
I want to put in a 1.6L SOHC head/block/ecu.
I do not need to replace the tranny
It should bolt in.
All I have to do it rewire.
Sound about right?
Where can I get the engine/ECU and how much am I looking at?
Also, if i were to do an exaust system first(i think the cat is plugged) would it bolt to the new engine and will any 88-91 header bolt on to both the 1.5 and 1.6? Also, where's the best place to get a header?
Arb out
my ride: 89 Civic LX 1.5L Dual Point Injection
Old 09-05-2002, 12:35 PM
Melt's Avatar
Re: Do you count nos system?
Originally posted by nitrous93
I was wondering do you all count a person who use Nos as a cheaters way out of racing such as winning race? Cuase I like nos and it gives you more horse power like 250 shot.
You sir, are a moron :finger:
AF Bay Area Crew
Old 09-05-2002, 12:41 PM
mightytexn's Avatar
mightytexn mightytexn is offline
Send a message via AIM to mightytexn
A 250 shot of NOS? Go play with your eclipse buddies
Old 09-05-2002, 12:44 PM
Melt's Avatar
Cool, how much do the wires run?
AF Bay Area Crew
Old 09-05-2002, 03:46 PM
amy@af's Avatar
engines you should find starting at $500. ecu is around $150. and i sereiously recommend the $150 wiring harness. you can rewire the 50 wires but really, it's more trouble than it's worth.
since you only have the LX, you should get the EX tranny. hatch Dx=4 door LX. hatch Si=4 door EX. you can find one used from $150-250. i wouldn't suggest it if it didn't make the world of difference.
as for the MPFI, you'll get most the parts needed to do the conversion on the new engine. the link i posted earlier has the how-to.
are you on the east or west coast? don't want to suggest an engine source on the wrong coast
Old 09-05-2002, 04:07 PM
Tony's Avatar
TLD Member #1
I think they cost me about 60-70 bucks.
Tony
What Beetle do i have adamchrissy Type 1 12 08-20-2013 04:53 PM
94 Honda Civic 1.5 5-speed jmando25 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 02-18-2010 05:23 PM
its amazing what can happen in a month slammed89civic '88 - '91 Civic | CRX | Wagon | Shuttlee 20 12-09-2002 04:33 PM
