starts fine but dies after running for a min
i have a 1994 grand prix with the newer 3100 v-6, it starts fine but after running for a min. it dies... but it starts right back up, but if you sray throttle body cleaner in it, it stays runnin.... i changed fuel pump, filter,cam sensor,both crank sensors, oil pressure switch, fuel regulator,sent the computer to get reprogrammed(flashed),check the voltage at the injectores(getting 12.3-12.5) to all.....any suggestions?
Re: starts fine but dies after running for a min
Have you tested fuel pressure (with a guage) and for loss of spark when it dies? Just because you changed the fuel pump doesn't mean it's not the problem, especially if you bought a generic Master or Airtex pump, as they are problematic. Also, it could be an ignition module or coil(s) failing.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
i finally found out what was wrong with it.... i had a short in the wireing in the fuel injector wireing harness...
That seems to be sorta common with the 3100...I've noticed mice like the area under the plenum.
2007 Certified DaimlerChrysler Service Technician... True blue GM at heart. |
