Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-07-2006, 09:44 PM
rlibke rlibke is offline
talon blues
I have a 95 eagle talon 2.0 turbo am having trouble with. the engine has been replaced with a 1st gen. with the 95 head on it. the engine is running so rich it turns the sparkplugs black in minutes, runs very rough, or dies. it has 170 lbs. cranking compression on all cylinders. i have been told it should have about 18lbs. vacuum at idle but it is only about 12. i have checked vacuum hose routing and condition and everything looks good. any ideas?
Old 10-07-2006, 10:20 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Re: talon blues
Do a leak down test and a boost leak test. Sounds like you might have a disconnect vacuum line possibly. Do you hear hissing when the car is running from anywhere?
Edit: P.S. Thanks for typing so I didnt have to try to decipher "retard" aka good grammar and using the proper subforums , it means a lot to us here on AF.com and also, welcome to the community.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 10-07-2006, 10:40 PM
Re: talon blues
I'll try the tests and search the lines again. I can't hear any extra hissing but i'll check anyway. Thanks for the compliment, I dont like to try to figure out whatend someone is trying to scrach either!
Old 10-08-2006, 04:07 PM
Re: talon blues
I have made progress! I could'nt get a hold of the guages for the leak tests but I confermed no vacuum leaks. Also previously I did'nt have all the clamps tightened on the hoses for the air intake. I tightened them all up to make sure there was'nt noise interfearing with hereing vacuum leaks and could'nt believemy ears! I still need to get a muffler on it and fresher gas. With that done I think it will be a lot better running. Thanks for the help!
Old 10-08-2006, 05:27 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: talon blues
Fresher gas? What's in there now?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-08-2006, 07:41 PM
Re: talon blues
The car had been setting for possibly a year.
Old 10-08-2006, 08:09 PM
Re: talon blues
Yea that could be it, the gas probably separated.
95 Eclipse GS-T
Currently:
Soon lol
Old 10-15-2006, 09:32 AM
Re: talon blues
I got fresh everything in the car and it runs great now! Thanks for the help!
