Old 10-07-2006, 08:08 PM
Blazer Daddy Blazer Daddy is offline
Thanks! and Blinker Problem
Hey guys,
Wifes got a 97 blazer that recently just died. I found this forum and based on your posts I guessed it must be the ignition switch module. I got one from Advanced for $100, put it in and back on the road again. Thanks for your help.
2 questions:
1. I broke the red plastic hazard switch and the dealer wants $300 + for the entire blinker assembly. Is that correct? I pulled the broken one out but he claims you can't buy just the red push down plastic piece which I broke. Is the junk yard the only option?
2. For the past 2 years when the headlights are turned on the left blinker green arrow in the dash stays on constantly unless you turn the left blinker on and then it blinks propery. Hence the default position is constant on rather than off. With the headlights off the left blinker indicator arrow stays off unless the blinker is activated. The right side blinker green arrow works as it should with the headlight on or off. What's up with this? Any suggestions?
Thanks for the great assistance!!!!!
Old 10-08-2006, 11:30 AM
muddog321 muddog321 is offline
AF -Advisor
Re: Thanks! and Blinker Problem
Theres a recall on 2000-2002 on just that part of the harzard switch and it pulls out - ask the dealer if its the same switch and then yes they have it.
Sounds like the blinker is due to the multifunction switch in the column or the plastic return piece for the blinkers that shuts it off after a turn.
Old 10-08-2006, 11:39 AM
blazee's Avatar
blazee blazee is offline
Problem?
They sell the replacement button. GM #15174447
The procedure is in the How-to section:
http://www.automotiveforums.com/vbul...d.php?t=595263
Old 10-08-2006, 09:53 PM
alblogg's Avatar
alblogg alblogg is offline
Originally Posted by Blazer Daddy
Hey guys,
2 questions:
I don't know how hard it is to get to but if you can take that bulb out and replace it. Sometimes this works if it don't probably what happen is the circuit board is touching there for the inst lites and that signal lite.
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'98 Pontiac Grand Prix GT, 3.8
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
