Old 10-07-2006, 07:30 PM
TWebster TWebster is offline
First Amp Installation
I hav ejust bought a new amp for my car and have gotten the power hooked up to the amp. The next thing I need to do is get the speaker wires and REM wire hooked up so the amp will turn on. I have my stock radio in and need to know what wires I need to hook up to the amp to finish the install. My problem is I dont know what wires are the ones I need to hook up. My car is a 92 Chevrolet Lumina. Please help.
-Webster
Old 10-07-2006, 09:04 PM
dbfreak147.5 dbfreak147.5 is offline
Re: First Amp Installation
if you just bought the amp it should have came with a hi level hook up harness what you have to do is find the factory wire from the rear speakers and tap into them once you figure out which one is positive and negative look at your hi level and put the positive on positive negative on negative and plug it into the amp and your done, if you amp is running subs turn the low pass filter on or every tone in music will come through the subs and it can damage them
2 Orion HCCA 10'S
2 AudioPipe 3k's
Adam Whitehead
Old 10-07-2006, 10:08 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
wow, I thought you had like fallen off the planet .....
