Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-07-2006, 03:26 PM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
engine is out now some questions.
me and dad are done taking out the egine now, we took it apart and found out that one the "half moon thingys' that goe where the crank connects with the rod moved and went on top of the other one. so that's why the engine wont turn over. now my questions are, would i be fine of i just replace those things and how do i order them(name)? also how do i tell if the engine is a 6 bolt? do i just count the bolts the hold the crank and clutch together?
heres is some pics. and a a litle video, you wont understand because it's in spanish, but it's basically me asking my dad what happend and just talking about what might have caused it to happen.
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 10-07-2006, 04:33 PM
E-Klips E-Klips is offline
Banned
Re: engine is out now some questions.
Those "half moon thingys" are called rod bearings.
You cant just replace and you're done. You need to check everything to make sure it isnt screwed up. Have you or your dad ever rebuilt a motor before? If not I would suggest having the motor built for you and you put it back in the car or have whoever builds it put it in the car. That is just my suggestion due to the fact that if you dont do it right, it is more likely to fail right away so it would have been a big waste of time/money.
Count the number of bolts that hold the flywheel to the crank. That is what motor you have... 6 bolt or 7 bolt.
You most likely screwed up the crank and rods due to the fact that the bearings spun. So you will either need to get them machined or get new ones.
Old 10-07-2006, 08:36 PM
my dad has rebuilt engines before but not me, i was asking just to see if it would be a cheap fix and i could sell the engine, now i just need to find a nice 6 bolt.
-MODS-
Old 10-08-2006, 12:47 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
I say go hybrid.. Go with Hyundai 7bolt Stroker with 1g rods...
DSM geek
Old 10-08-2006, 01:54 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Get rid of that 7 bolt shit. Might as well go 6 bolt, theres no better time to than now. Hit style, I am sure someone there has a spare 6 bolt. Chances are if the bearing spun around long enough to get on top of the other one there is significant damage to the crank and rod and quite possibly some nice scoring on the cylinder walls. I would sell of whats salvagable and save for a 6 bolt.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 10-09-2006, 10:31 AM
[quote=Thor06]Get rid of that 7 bolt shit. Might as well go 6 bolt, theres no better time to than now. QUOTE]
yeah, my asked me what i wanna do,i've looking at stuff that would be good to replace since the engine is out.
i was looking at the act 2100 from extremepsi.com, right now is 376 but you get 15% off at check out, but i'm not sure if this is a good price and i dont see a flywheel in the pictures. here's the link.http://www.extremepsi.com/store/cust...cat=253&page=1
and now i'm gonna do my motor mounts, at work they have a hydraulic press and i think one of the engineers will help me. since it's gonna be a 6 bolt, i have to buy for a 6 bolt right?
and last, do i really need dsm link? i heard somewhere that dsm is used to take care of missfires when upgrading to a 6 bolt.
-MODS-
