Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 10-07-2006, 01:43 PM
dohdoh dohdoh is offline
Question help!!!!! about to go crazy!!!!
okay heres the scenario, when i turn the key to on, but dont start the car , the temp gauge instantly goes to hot!?????????????
i changed water pump, fan switch sensor, temp sending gauge switch, and my gauge cluster.....
i ripped all the shrink wrap off the wiring harness and the wire conditions are normal, (no burnt/crispy wires) no severs, no exposed wires,
help!!!! anyone have a problem similar to this before ...
now keep in mind , the has been sitting and not even ran, so i know engine is cold, but when the ignition is turned to on (but not started) instantly goes to hot?????/
i also check all fuses, all are intact
what the hell can be causing this?, its about to make me crazy
and i will not drive my car without a temp gauge
Old 10-07-2006, 10:42 PM
Markb873 Markb873 is offline
Re: help!!!!! about to go crazy!!!!
There are 2 ECT senders did you change both? One reports to the PCM and the other to your guage. I'm thinking you changed the one that has the LG/R & GV/R wires. But not the one with the W/LB & BK/W which is the one that works the dash guage. If you changed them both and the guage then you have to have a short in the wiring.
Hope this helps,
Mark
Old 10-08-2006, 11:34 AM
Thumbs up Re: help!!!!! about to go crazy!!!!
yeah i figured the same thing, that it was probably a short i couldnt see, i went and got a wiring harness from the salvage and replaced that whole damn harness, and it worked fine, i totally cut aprt the old harness and found a spot where both wires were exposed!!!!!
it worked like a charm, at least i got a gauge cluster that only read 68,000 miles , plus since i had the gauge cluster out i put in my glo gauges shit looks tight
Old 10-08-2006, 12:11 PM
Must of been a short to power, wonder what the other wire went to. Glad to hear it's fixed. Talledega will be on soon, gotta go.
