Old 10-07-2006, 10:46 AM
jsado13 jsado13 is offline
2000 dead jimmy! never had a problem, now it's dead!
I own a 2000 GMC Jimmy that I bought about 5 months ago. Up until yesterday, I loved it. Everything is great on the truck. 82,000 miles. I started the truck yesterday, after letting it sit for about a week, it ran for three seconds then shut off. Now there is no power to any part of the vehicle. The battery tests good. There is power going to the alternator and going to the starter. No power going to the fuse box though. Once in a while, I hear the truck try and work. It makes a few clicking noises, especially from underneath the fuse box on the little black box marked "starter".
Is it possible that the starter is bad? I have power going into the starter but nothing coming out. Any help here wold be huge.
Old 10-07-2006, 01:55 PM
Re: 2000 dead jimmy! never had a problem, now it's dead!
Okay, so I pulled the starter wires off. Thinking that if there was a short in the starter, I'd be good with it disconnected. Still nothing. Also, I forgot to add that the key will not return to it's off position and they are stuck, and I cannot move the transmission from park even when the key is in the on position. When I hear the occasional clicking noise and half of a "door open with keys in the ignition" chime, I can then pull the key out of the ignition. Help me out here folks. PLEASE.
Old 10-07-2006, 01:57 PM
ALSO, I wanted to add that whatever the silver box on the passenger side located behind the kickpanel is, that also makes the clicking noise occasionally.
Old 10-07-2006, 02:02 PM
alblogg's Avatar
alblogg alblogg is offline
Does this Jimmy have an alarm system on it or remote starter?
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'98 Pontiac Grand Prix GT, 3.8
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
Old 10-07-2006, 02:28 PM
It only has the factory security system in it. That was one of my thoughts though. Perhaps it is something to do with that.
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Battery cables and grounds to start with.
Have you got horn or lights or blower motor operation.
Start at battery and work back to fuse panel with a test light and look for lose of power.
MY
MT
Old 10-07-2006, 02:32 PM
I have no power whatsoever throughout the vehicle. No lights, horn, acessories, dash lights, gauges...etc....The gauges do appear to be stuck in some sort of mid point positon. Occasionally, when Im hearing the clicking noises, the gauges move around...up and down...then they freeze halfway.
Old 10-07-2006, 02:49 PM
MT-2500's Avatar
AF - Advisor
Clean and check battery cables and grounds.
Check battery for 12 volts and carrying load.
Then get a volt/meter or 12 volt test light and start at battery and work back to fuse box and check for lose of power.
MT
MT
Old 10-07-2006, 02:51 PM
I don't know where to begin! I follow the wires as far as I can see them, but then what? Do you know of any specific places I should be looking?
Old 10-07-2006, 03:12 PM
MT-2500's Avatar
AF - Advisor
Well you got to start some place.
It sounds like a dirty battery cable or bad battery post or battery to me.
Check all battery cables first. Clean battery post and cables
And ground on engine.
Start at battery and go as far as you can see or you may find it right at battery.
Some of them get there power from starter post.
And some have a fuse link there.
If all else fails get a good factory manual or a All data sub and trace the power feeds from the wiring diagram.
http://www.alldata.com/products/diy/index.html
MT
Old 10-07-2006, 03:17 PM
MT-2500's Avatar
AF - Advisor
On yours there is a 175 amp battery fuse in the underhood fuse box on rightside of rad.
Make sure it is good.
Power on both sides.
MT
MT
Old 10-07-2006, 04:44 PM
Here is an update. I wanted to disconnect the starter to see if that would change anything as far as getting power to the rest of the vehicle. SO, I touch the first bolt, crank it a little.....and snap!....SO, I buy a new starter and install it. There as no room for error because the starter has specific size posts for specific size cables. Install goes well....As soon as go to reconnect the battery, the engine starts turning over, all by itself. No power to anything still, but the engine turns over all by itself. So, I undo the two mounting screws on the starter, let it hang out of the bottom of the truck, reconnect the battery---and nothin. nothing at all happens. Maybe the starter connected creates some type of ground?
Old 10-07-2006, 04:45 PM
MT
I wish I could check it....But I don't even get power to the fuse box!
Old 10-07-2006, 06:46 PM
MT-2500's Avatar
AF - Advisor
I am not sure what you did or did not do there but.
It sounds like you had better get someone to help you with it.
Good luck
MT
MT
Old 10-07-2006, 07:40 PM
alblogg's Avatar
I don't know what that silver box on the pass side is on yours you hear click but on my '99 it was my remote start and alarm box. It has a 12 pin conn coming out. My Blazer was doing the same thing and I though my battery was fully charged because I just charged it but the wires had come off my kicker in the back and was touching. This was hooked direct from the battery with an in line fuse 50amp but the fuse never blew so it drained my battery down fast. So be sure your battery is fully charged and maybe look for a drain.
Tuner,Viper
Allen- Paintman
Wrenchtwister
Broompusher
