Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-07-2006, 09:12 AM
elopez2 elopez2 is offline
Unhappy 1998 Isuzu Rodeo AC troubleshooting
Guys have a leak on my AC how can I check for a leak on the AC System? I tryed to read the pressure but nothing compressor is dead, I'm able to jump start it. It works but there's not pressure on system. Need help!
Old 10-10-2006, 07:28 AM
redbug redbug is offline
Re: 1998 Isuzu Rodeo AC troubleshooting
Compressor will not start on it's own due to low pressure shut off.... I believe there are some freons with red dye that you can put in the system to help you find the leak? Check for oil build up around the connections, usually the oil from the system seeps out where there is a leak... How about soapy water? If the compressor is oily around the compressor clutch that is usually a good sign that the compressor is leaking.... Any pressure at all in the system?
Old 10-12-2006, 09:16 AM
It's kind a weird whenever I jumper the compressor pressure comes down. I will try to check system with soapy water and with compressor on. Pressure seems to go up if compressor is off?
Old 10-12-2006, 05:52 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
You must be looking at the low (suction) side. When the compressor is running the low side will drop and the high side should go up. When the system is shut off both sides will equallize. I agree that your system is probably low on charge and the low pressure switch wont let it run. I will cut out around 25 psi and back in around 29 psi.
Here is what the FSM for a '99 rodeo says is norma pressures..
Normal Pressure:
 At ambient temperature: approx. 25–30C
(77–86F).
 At low-pressure side: approx. 147.1–294.2 kPa
(21.3–42.7 psi).
 At high-pressure side: approx. 1372.9–1863.3 kPa
(199.1–270.2 psi).
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 10-13-2006, 02:37 PM
Thanks I will try to charge system and from there!
