Old 10-07-2006, 02:41 AM
strongboy2005 strongboy2005 is offline
Send a message via AIM to strongboy2005
Results from my compression test
I think the numbers speak for themselves:
Cylinder 1 - 190 psi
Cylinder 2 - 135 psi
Cylinder 3 - 150 psi
Cylinder 4 - 170 psi
The car in question is a 1999 Chevy Metro Lsi 4-door sedan, 1.3L inline four. These were my results for the compression test I just did. I'm wondering, is this normal for an engine with 86,000 miles on it? Should I be worried about such huge differences in the data? ...or is it time to sell my car...
Any help would be greatly appreciated...
Old 10-07-2006, 09:46 AM
Blue Bowtie's Avatar
Registered Offender
Re: Results from my compression test
The difference (in percentage) is more important than the actual numbers. You have a large variance with #2 and #3, so make sure the valves are closing fully. you can try injecting a couple ounces of clean engine oil through the spark plug hole and repeat the test on the low cylinders. If compression increases, that can indicate waorn rings. If compression remains the same, that can indicate leaky valves, or possible mechanical damage to heads, pistons, or cylinder walls. Given the relatively low mileage, I would tend to think it is a valve sealing problem.
Old 10-07-2006, 11:01 AM
Teal95Jimmy's Avatar
Teal95Jimmy Teal95Jimmy is offline
Send a message via AIM to Teal95Jimmy
If you notice it is adjacent cylinder so it could be a head gasket problem too.
Old 10-07-2006, 05:36 PM
I redid the tests after adding a cap-full of oil to each cylinder.
Cyl 1: 265
Cyl 2: 260
Cyl 3: 280
Cyl 4: 295
Cylinder 4 actually ended up getting half a cap of oil more than the others, and my buddy is unsure if the first two were completely "done". Nevertheless, they all seem quite a bit higher than the compression numbers I got earlier.
Old 10-08-2006, 12:18 PM
534BC 534BC is offline
Wow, that's a huge increase. Blue gave you perfect advise. Rings, rings rings.
You may also test the blow by by removing oil cap and revving engine. The engine seems very worn out to me.
Old 10-08-2006, 12:25 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
I would almost suggest, due to the cylinders most affected (2,3) that there's a head gasket failure between cylinders.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 10-08-2006, 05:04 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
http://www.auto-rx.com/rms13/about.htm
Try Auto-RX.
It will release your rings. This has been proven to work time and time again.
Check out his tests and they have been verified.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 10-08-2006, 10:35 PM
That may be a good guess especially if the cylinders are siamesed, does anyone know? Adding oil probably will not help a gasket.
Something about those compression numbers just doesn't seem to be consistant. How about trying a leak-down test?
Old 10-08-2006, 10:41 PM
BlazerLT's Avatar
AF -Advisor
http://www.auto-rx.com/rms13/stats.htm
Old 10-08-2006, 11:09 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Just pull all the spark plugs, put the cylinder in question on TDC, and put shop air into the cylinder thru the plug hole, and then listen to where the air is escaping. Listen to the intake(Intake valve), exhaust(Exhaust valve) and the dipstick tube or oil fill cap(Rings), and lastly the adjacent cylinder plug hole(Head gasket).
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 10-08-2006, 11:12 PM
Originally Posted by corning_d3
Just pull all the spark plugs, put the cylinder in question on TDC, and put shop air into the cylinder thru the plug hole, and then listen to where the air is escaping. Listen to the intake, exhaust and the dipstick tube or oil fill cap, and lastly the adjacent cylinder plug hole.
That's a " " leak down test.
Old 10-08-2006, 11:15 PM
I know, I was just explaining how to do one since no one else did...
Old 10-08-2006, 11:24 PM
I was just razzing you anyways. I had a lot of spaces in between quotes and was afraid to offend certain groups so choose what ever you want to put in-between.
Your tips are great.
Old 10-08-2006, 11:27 PM
Hehe, i figured you were only kiddin' around. I'm not at all easily offended anyway.
Old 10-13-2006, 07:37 PM
Wow that Auto-RX stuff is like $20 a bottle... Do any places sell it (Autozone, Kraigen, Pep Boys) or do you have to buy it online?
Is there anything similar to Auto-RX that could get the job done for cheaper ($20 for a 12 oz oil additive!?)
Thanks for all the replies.
