Old 10-07-2006, 02:56 AM
thinmints thinmints is offline
96 XJ Flushing the Motor??
My xj has 180k on her and i was wondering what you can do to Flush the motor of all the years of build up in the motor. she doesnt burn oil or leak much at all.. i have seen that can of motor flush at wally world but does it really work? anybody try this ? let me know
Old 10-07-2006, 07:35 AM
gtmud gtmud is offline
Re: 96 XJ Flushing the Motor??
Thinmints,
First, have you changed the oil regularly and kept with the same brand name and type? If so than I would leave the engine alone, doing the engine flush has been known to lead into more expensive repairs with higher milage engines. If you want though, I would look at flushing the coolant system. I work at a Ford garage, and we use a flush kit made by Wynn. Seems to work good, except for the occasional plugged up heater core.
The key is, if all is working well, tranny fluid is still red, coolant- green,and oil pressure still good. You should be fine. If regular maintenance has been done all along.
Old 10-07-2006, 12:23 PM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Cool Re: 96 XJ Flushing the Motor??
recommend doing a search on the web for:
synthetic engine oil flushing
IMHO I just use a synthetic or a blend I do myself using the same brand (50-50).
Never used a flush myself though.
Old 10-07-2006, 12:26 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
I've used this product, it worked well and as advertised, without the harshness of motor flushes. www.auto-rx.com
and gtmud is correct - if you've changed all your fluids regularly, you shouldn't have a problem. I change my coolant every year and a half whether it needs it or not, and I have never had a corrosion problem or radiator failure in any of my vehicles.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
