| General Tools Discussions about tools - there are thousands of various tools you can use to work on your car. Do you have the right one for the job? |
Floor Jack Check Valve Repair
Has anyone ever repaired a floor jack which appears to have a bad check valve? Piston extends slightly when jacking, but then returns under spring load when jack handle is returned. Would valve be directly under handle piston, or would it be in a separate access port. Any comments/suggestions would be appreciated.
Re: Floor Jack Check Valve Repair
Replacing it is pretty easy, finding a replacement is probably going to be the hard part.
Thanks for the comments. In this model, there's a cast-in port with an access plug. I'm presuming I'll find a spring & ball somewhere inside. If the ball isn't obviously damaged, then I'm not sure what would be next. Maybe the seat will screw out. Thanks.
