Sunfire Rotars???
Ok so im just wondering recently replaced my control arm due to a minor accident with a curb, so neways after replacing it i nticed it was still making some noise almost liek somethign was rubbing so after taking it apart and what not i found it was maybe the brake pad on the rotar beacsue the rotar had some cuts in er or (warping) , so i replaced the rotar and its still making some noise, so im wondering wut could be possibly wrong?the brake assembly itself is bent or??? i have no clue maybe over pressure somehow is making it clamp all the time ??? any help is greatly appreciated! thanks alot guys |
Re: Sunfire Rotars???
and my brake pads sorry
It is possible that you damaged the bearing when you hit the curb. That would account for the rubbing noise that you hear.
K well i had it on jack stand and i was reving it and it was almost sounding like it was coming from directly under my engine. So i dunno is the bearing located near the transmission? or should i maybe be worrying that it may be my transmission??
there is no grinding between gears so im doubting that or anythign to do with cahgning gears so my best guess is a bearing too.. but where abouts would i be looking for the bearings>? and if not has anyone heard of something similar? coming from the same area?? its no crazy loud but its defenitly noticable when driving... thanks alot for your response and any to come!!!any help is appreciated!!! thanks!
K so im getting some weird noise from my passenger side wheel well thats prety much only noticeable from inside the car. I jacked it up and ive come to teh conclusion its coming from therebut since nothign i see is bent im wondering if it iis maybe a bearing? or a tie rod??
i noticed the wheel wobbles a very small bit like maybe 2 mm when its in gear and the tires are going. I only get this sound when its over 40 km an hour, im just wondering if anyone would know wut im maybe looking at to fix?? and if anybody has seen anythign similar. It sounds like a metal scrapping almost and im scared to drive it though it drives perfect. When totally cranked to turn there is no sound from the wheel wells its only when im driving straight can anyone help!!! thanks alot if u can!!!!!!! thanks alot!!! |
