Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-06-2006, 06:21 PM
GreyGoose006 GreyGoose006 is offline
F40H.D. vs. F41
what exactly is the difference between the F40 and F41 suspension options on the 80's caprice sedan.
specifically the 84' sedan.
i was looking at a sales brochure and was just curious what qualifies as Heavy duty versus Sport
seems like stiffer sway bars would be a sport part, but could also qualify as heavy duty since they were standard on the front anyway. stiffer shocks are definetley a sport part, but could also be heavy duty if the valving was geared more towards hard use on rough pavement...
i'm confused
Old 10-06-2006, 07:36 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: F40H.D. vs. F41
F40 Suspension System, Heavy Duty Front and Rear
F41 : Suspension System, Front, Rear, Firm Ride, Handling
F41 has rear anti-sway bar.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 10-06-2006, 07:37 PM
capriceowns capriceowns is offline
Re: F40H.D. vs. F41
nvm my post, silicon nailed it.
1987 Chevrolet Caprice classic Brougham. 142,000 on the 305 and still chugging
Old 10-07-2006, 07:48 AM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: F40H.D. vs. F41
So, what do I have on my '84? (or did I used to have when it was stock) I dont have a sway bar on the back, only on the front.
Old 10-07-2006, 08:54 AM
Blue Bowtie's Avatar
Registered Offender
Re: F40H.D. vs. F41
See above. It's probably F40, but the RPO list/SPID label would clarify that. 1984 should have had a white/gray RPO label in the trunk, and may have also had the boilerplate on the firewall (I believe that was the transition year in most assembly plants).
What you have is mush. That's great if you're just boulevard cruising. If you want a little more compliant steering and ride, you might want to look at new springs with the same height but a higher rate, especially since your springs are 20+ years old. Think about a larger stabilizer bar up front, like BMR or Hotchkiss F-Body 1½" types (with new bolts and new end links), and installing a rear bar. Some station wagons had a large rear piece, but they aren't anywhere as stiff as the F-Body types. A fresh set of monotube shocks with tighter rebound control will help. And make sure you have a full compliment of body mount bushings (see Scott Mueller's article at http://www.theherd.com/articles/bushings.html).
Old 10-07-2006, 09:19 PM
Re: F40H.D. vs. F41
i was looking for maybe a list of parts for each one that was bolted on to qualify the extra cost of each.
mine has neither, but i was wondering what was in the packages, and what the differences were.
Old 10-08-2006, 09:20 PM
PeteA216's Avatar
Re: F40H.D. vs. F41
As for my suspension, I've replaced the entire thing minus some bushings and body mounts. The springs were replaced in the rear with a variable coil spring, which is supposed to take weight better, and the shocks have been replaced with Monroe ltd lifetime shocks. Its nothing special, but It helped out big time having replaced the near 23 year old suspension. They've been holding up a lot of weight for a long time. Im not TOO worried about the handling... I mean well, it doesn't even compare to the handling of a newer car, but the ride is smoother than ANY new car I've ever ridden. Don't get me wrong, new cars have a smooth ride, but its a different kind of smooth. As for a rear stabilizer bar, I heard that stabilizer bars can take away from the smooth ride, and don't do as much on a solid axel as they do on an independant suspension. Just my .
Old 10-09-2006, 09:35 PM
Re: F40H.D. vs. F41
lets try it this way:
i'm a prospective buyer of a brand new 84 caprice classic, and you are a salesman trying to sell one of the last three on the lot before the end of the 84 model year. one has an F40 suspension and one has an F41. the other has the stock, no options suspension.
you are trying to sell me the F41. (more expensive)
i am asking you why i want to spend the extra $49 and what it will get me.
what is in it that is better than the $26 HD suspension or the free stock suspension.
SELL ME THE CAR.
i want to know the parts involved in the extra cost
Old 10-09-2006, 10:20 PM
silicon212's Avatar
Confoundingly Lucid
Re: F40H.D. vs. F41
Well, the F41, as on a 9C1, comes with Bilstien shocks, stiffer springs, and that rear sway bar. It gives a rougher ride than the pillow-soft stock suspension, but carries the corners where the stock won't. The rear sway bar in conjunction with the valving on the shocks helps to keep the car more level during cornering and helps keep the tires on the road, where they belong.
I'd get the F41 suspension, if no other reason than for safety reasons - at high speed and when the road is wet or during other adverse conditions, it's nice to know that the tires will hold the road as good as they can.
Old 10-09-2006, 11:07 PM
PeteA216's Avatar
Re: F40H.D. vs. F41
Now thats one heck of a sale's description right there!
Old 10-09-2006, 11:59 PM
Re: F40H.D. vs. F41
so basically, F41 is code for 9C1?
Old 10-10-2006, 12:26 AM
silicon212's Avatar
Confoundingly Lucid
Re: F40H.D. vs. F41
I believe it was also on some later model Broughams, 1986 and newer.
Old 10-16-2006, 08:20 PM
1968 Pontiac's Avatar
1968 Pontiac 1968 Pontiac is offline
Re: F40H.D. vs. F41
Will the front F body sway bars fit on the front of a B body car? I just saw a 80's iroc z front sway bar in the wrecker. Looked like a fairly stout piece.
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis single rear wheel pick-up truck)
1968 Pontiac Parisienne (rust free survivor)
1973 Buick Centurion (four door hardtop; engine will be donated to our 1949 1 ton truck)
1989 Chevrolet K3500 RC/LB (454 & single rear wheels)
1991 Chevrolet Caprice Classic (police cruiser clone)
1992 Chevrolet K2500 EC/SB (almost rust free daily driver)
1998 GMC C1500 EC/SB
Old 10-16-2006, 09:02 PM
Re: F40H.D. vs. F41
it should if the lengths are the same.
CD smalley or someone wrote a really good thread on how to make caprices handle better, and outlined all the parts that fit.
its called how to make a b body handle on a budge or something like that
Old 10-17-2006, 07:56 AM
Re: F40H.D. vs. F41
Found it:
http://www.automotiveforums.com/vbul...d.php?t=321620
However, I have a few 9C1 rear sway bars and found there are two different attachment methods:
The earlier (I'm guessing 91-93 and before) sway bars attach to a short channel with two bolts through the holes in the sway bar, then this channel is slid into the lower control arm and fastened with two self tapping bolts from each side. The channel is still available from GM as I bought them a few months ago. This method of attachment will work for any B (and C?) body sedan (not wagon) from 1977 and up as the lower control arms have the required holes to fasten through to the sway bar mounting channel.
The second method (from 94-96?) will require a change on lower control arms as the same sway bar as used above is attached with long bolts through the top of the lower control arm right throiugh the mounting holes in the sway bar. There are a couple of small steel brackets the keep the sway bar in place. Less parts required, which is probably why GM switched the attaching method.
Which method provides better handling? I don't know. But from all the rear sway bars I've seen in the wreckers, the second method is definatly better if you don't want your lower control arms rusting out, as the moisture can drain away. Of course if you undercoated your car from new, you won't be worrying about rusty control arms.
