Old 10-06-2006, 06:06 PM
weidnerr weidnerr is offline
98 3000gt auto
Looked at a 98 today and the tranny sometimes shifts a little hard into overdrive. I think the car has set for a couple months. It has 120k on it....That's the only problem I noticed. Does the 98 have any overdrive problems?????
Thanks,
Rob
Old 10-06-2006, 06:12 PM
Re: 98 3000gt auto
I was driving it on the interstate about 70 mph in drive and then hitting the button on the stick to put it in overdrive. Not running it hard just going through the motions. It doesn't seem to do it if I just leave it in overdrive all the time. At least it didn't while I test drove it about 20 miles.
Thanks,
Rob
Old 10-06-2006, 08:54 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: 98 3000gt auto
so you want an auto? not a manual?
just fyi, i'm pretty sure the auto only came on the base models, if so, you have a SOHC motor. very slow.
you might be aware of that and you might indeed want a manual, but to me it just sounds like you want a 3000GT so bad that you'll take whatever you can find. if i'm wrong, let me know. i just wanted to tell you that there's always another great deal around the corner, so don't jump at the first car you find. and make sure the car has low miles and has been taken care of...you'll be much happier down the road when you don't have to spend $1000 on parts/labor for routine maintenance.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-06-2006, 09:07 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: 98 3000gt auto
Since when isnt there a DOHC ATX?
Old 10-06-2006, 10:25 PM
StealthModifier StealthModifier is offline
Re: 98 3000gt auto
id stay away from an auto. ive had nothin but problems with mine since ive had it. unless ur gonna drive like a grandma all the time it wont matter. but if u want pickup the atx doenst have any until u hit 40 or so.
Old 10-06-2006, 10:36 PM
Morphius289's Avatar
Morphius289 Morphius289 is offline
Re: 98 3000gt auto
^holy crap, look who's back.
Black 1997 3000GT
Originally Posted by Igovert500
[01:05] Igovert500: scrwe his method
[01:05] Igovert500: too much crap
[01:06] Igovert500: i just jam a garden hose in there
[01:06] Igovert500: and put it on high flow
[01:06] Igovert500: go the opposite direction too
[01:06] Igovert500: so it clears out more shit
18 and out of debt - member #1
Old 10-07-2006, 11:56 AM
Re: 98 3000gt auto
has it been that long?
