Old 10-06-2006, 06:00 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Some fairly extensive brake work
Hello all. I've been troubleshooting my brake system the last week or so and I've come to the conclusion that my master cylander is leaking into my brake booster. Since all my hoses are cracked too, I figured I would just spend a Saturday (tommorow) swapping parts out.
I'm getting a brake booster with the master cylander already attached from Autozone (remanufactured GM stuff) and I was wondering what it takes to replace mine. I flipped though my service manual and it looks like I need to remove the lower hush panels on teh dash, remove a cable from the brake pedal, then remove 4 bolts holding the BB on the firewall. Next, I need to disconnect all my brake hoses from my master cylander and after that the whole MC/BB unit should just slide out of the firewall.
Is this right so far?
After I get these swaped, I need to remove the brake hoses and put the new ones on. At this point I'm ready to bleed all the lines with a fresh bottle of fluid.
Am I missing anything? Is there anything else I need to consider replacing while I've got it apart? Or do I pretty well have the general idea?
Parts come in tommorow so I'll post when I'm not mechanicking.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 10-06-2006, 06:21 PM
maxwedge maxwedge is offline
A990 racer
Re: Some fairly extensive brake work
Bench bleed the master cylinder before installing, also.
Old 10-07-2006, 01:27 AM
Alibi's Avatar
How do I bench bleed the MC? run fluid through it before I connect it to the brake lines?
-Eric
Old 10-09-2006, 02:32 PM
A990 racer
Yes, put fluid in it and push the plunger in till fluid come out the ports.
Old 10-09-2006, 03:26 PM
Alibi's Avatar
Cool. The parts came in today so I'll update probably wednesday when I get the job done.
Thanks for the double-check
-Eric
