Go Back   Automotive Forums Car Chat > Geo > Nova | Prizm | Spectrum | Sprint
Old 10-06-2006, 04:10 PM
dhodson2004's Avatar
dhodson2004 dhodson2004 is offline
Send a message via AIM to dhodson2004 Send a message via Yahoo to dhodson2004
Angry Hard Start Hot
Hello again. I have another issue with my 1990 Geo Prizm. The engine starts up immediately when it is cold, or sitting for a while. When it is hot, I have to crank it over for a few seconds. Sometimes it will take two tries. I thought that it might be a clogged injector. I tried fuel injector cleaner a few months ago, with no help. Fuel pressure also crossed my mind. The engine is a DOHC 1.6L 4 Cylinder EFI Engine code:6. It is really annoying and embarrassing. This is me when the problem occurs: lol. Thank you!
Old 10-10-2006, 08:37 AM
paxfam1 paxfam1 is offline
Re: Hard Start Hot
It could be that your losing fuel pressure is leaking down, your going to have to put a gauge on there and do a leak down test. Have you tried priming the lines by turning the key on and off a few times. Could also be a bad fuel pump, I have seen this happen. There are other possibilities as well but go check for fuel pressure.
Old 10-11-2006, 09:01 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Hard Start Hot
Suggestion is to post your question about the Prizm in the actual section for it instead of the Blazer forum.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 10-11-2006, 10:05 AM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: Hard Start Hot
thread moved to the appropriate forum.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 10-11-2006, 11:14 AM
Re: Hard Start Hot
The post was already in there. Now you made a double post in the Prizm forum.
Old 10-11-2006, 12:04 PM
BlazerLT's Avatar
AF -Advisor
Re: Hard Start Hot
Then learn to follow the AF rules and post your question once.
