Old 10-06-2006, 12:07 PM
Billy_1225 Billy_1225 is offline
coil, distributer, cps???
My dad is trying to figure out his jeep comanchee. he says there is fire going to the bottom of the distributer from the wiring harness and that there is fire going to the coil. there however is not any fire from the coil to the distributer. is the cps the problem, can I test it? also the alternator isnt installed yet, would that cause anything like this???
Old 10-06-2006, 01:09 PM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Cool Re: coil, distributer, cps???
Let me see if I have this straight....so when he cranks it over, there is no spark from the coil wire? What year and engine do you have?
Old 10-06-2006, 03:05 PM
Dale Aeppli Dale Aeppli is offline
Are you getting spark to spark plugs? Have you checked condition of disrtibutor cap, rotor, also check the carbon button in center of cap, inside the cap. year and engine size. When you say fire do you mean actual spark or do you mean electrical voltage at distributor. Check for actual spark at coil and distributor, plugs [email protected] Dale
Old 10-06-2006, 07:27 PM
88 Jeep comanchee 4.0 there... I mean voltage. there is no spark through coil wire. there is voltage to bottom of dist and coil.
Old 10-06-2006, 08:16 PM
dad has replaced the distributer and coil. and is about to change the crank sensor.
Old 10-06-2006, 10:23 PM
AlohaBra's Avatar
88 model Commanche...MJ model
I don't know what the smog laws are like where U are at...butta...
look into a distibutor and coil without the computer stuff...like MSD..or Accel..
Just looked at manual for 88 XJ...looks like GM HEI with coil in cap...is that correct?
So it does not use the CPS.
There is another one on the 88 XJ that has a crank sensor, but don't know if your model is prone to a defective cps like the later ones.
Old 10-09-2006, 10:47 AM
coil is not in the distributer. there is a crank sensor
Old 10-09-2006, 01:36 PM
AlohaBra's Avatar
Any luck after the cps replacement?
Old 10-23-2006, 07:52 AM
wwwildman wwwildman is offline
First/ I would use an OHM meter to check the coil and the CPS. If those check out good then I would suspect the Cam position sensor (pickup/stator) that is in the distributor. If it is the Cam sensor you will have to remove the distributor to change it.
Good luck
Mike
