Old 10-06-2006, 10:17 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Loud Hum & Clicking
I have an extremely loud hum and click from the drivers side front and roars louder and louder and clicks. It had a slight hum for a few weeks and now it is so loud I can barely hear myself think! Roaring and clicking!!! Any ideas?
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 10-06-2006, 05:24 PM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
Re: Loud Hum & Clicking
could it be your ac unit?
Old 10-06-2006, 08:07 PM
83T/A98Blazer 83T/A98Blazer is offline
How can you hear it? J/K
I'm thinking possibly a front wheel bearing, does it get louder if you turn left or right? Another possibility is maybe a u-joint. They click or squeek, but I don't think I've heard them hum. I'm guessing it gets louder, faster clicking with speed. That would lead me to believe wheel bearing or a brake/caliper problem.
Old 10-07-2006, 07:55 AM
muddog321 muddog321 is offline
AF -Advisor
Look at the hub (larger tires), brakes, CV axle (boot ripped and grease all over),the front diff gear oil and bearings, and transfer case fluid to start. Jack up under the lower control arm so the CV is not binding and rotate the hub and listen and pull at 12 and 6 position and see if bearing play (watch the inside by the CV for play and not tierod play).
Old 10-11-2006, 04:04 PM
Come to find out it was the left front wheel bearing, it was junk I guess! Everything else was checked and a ok. Thanks guys
K&N Air Filter
Old 10-13-2006, 02:52 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
either the Front bearing and/or the CV joint are shot.
1995 Factory Blazer Service Manual for sale, PM if interested.
