Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 10-06-2006, 12:42 AM
neonyyy neonyyy is offline
Angry Won't Start. Pops into neutral
I think my battery might be dead but im not sure. When I turn the key it just clicks once and won't do anything else. I would appreciate some help.
I also have the problem of when I put my pedal to the floor the gear shift moves into neutral. I was wondering if it was a transmission fluid problem or transmission problem. Thanks for the help
Old 10-06-2006, 04:28 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Won't Start. Pops into neutral
Get the battery tested and replace if needed.
Check your shifter cables for your other problem.
2003 Dodge SRT-4
Old 10-06-2006, 07:49 PM
i got a new battery and it's still not working
Old 10-07-2006, 02:50 PM
Check your connections to that starter and make sure they are on there tight.
2003 Dodge SRT-4
Old 10-09-2006, 12:09 AM
thats what it was i had a loose connection to my starter. thanks. and i found out about why it pops into neutral from reading up on other forums. once again thanks
