Old 10-05-2006, 09:52 PM
kdiddy8 kdiddy8 is offline
93 vr4 leak
i have a 93 vr4. 3 months ago, mitsubishi put in a new transfer case because it locked up and bc of the recall. last couple of weeks looks like my transmission is leaking? are there seals that leak? i put it up on a lift but all we could really tell is that it looks like the green rectangular thing close to the wheel is leaking and running down the trans. but it smells like gear oil not regular oil??? any suggestions on what to do or common problems like this?
Old 10-06-2006, 12:24 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: 93 vr4 leak
there are only a few places the transmission can leak from. what your describing (the green thing on the axle), would lead me to think that it is leaking from where the axle goes into the differential. there is a seal, one on each side of the differential. there is also another seal at the output shaft. and lastly, check your tranny drain plug and fill plug.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
