Old 10-05-2006, 09:35 PM
wilfie27 wilfie27 is offline
What is MAT ?
After putting on a new water pump and thermostat my check engine light comes on while ideling. It goes off after I get up to speed but comes back on if I stop and idle for a few minutes. I hooked up a code reader and it said " 25 MAT is too high". Someone said it means "manifold air temp" but I'm not sure. Any help would be appreciated.
94 Firebird: 3.4L 220,000 mi
95 Blazer: LS 2DR/2WD 210,000 mi
96 Trans Port: work in progress
97 Silverado 4X4 Ex/cab: 200,000 mi
05 Malibu: 98K mi
08 Chevy Van: Direct TV work van
Old 10-05-2006, 10:00 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: What is MAT ?
25 – Intake Air Temperature (IAT) sensor or circuit – high temperature indicated - Inlet air temperature sensor signal showed an air temperature of over 218? F for 5 seconds when vehicle speed was greater than 35 MPH.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 10-06-2006, 12:00 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: What is MAT ?
Just had this occur with mine.
Just replug in the connector going to the air temperature sensor under the intake just before it enters the engine.
You remember to plug that sensor in?
Plug it in or remove and reattach. Then clear the codes and see if it some back.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 10-06-2006, 03:19 AM
Re: What is MAT ?
Thanks, oh yeah..... I forgot my serpetine belt did come off and shattered that sensor and I had to replace it. The orginal one was plastic and replacing it with another plastic one was $52, but the guy at O'Rielly's found a brass one for $12.99. I cleared the code when I scanned it so it should not be coming back on, at least not for that.
05 Malibu: 98K mi
Old 10-06-2006, 10:27 PM
BlazerLT's Avatar
AF -Advisor
Re: What is MAT ?
Huh?
what sensor are you talking about? The one on the bottom of the intake pipe?
It cost me 13 bucks to replace here at the dealer.
Old 10-07-2006, 11:19 AM
Re: What is MAT ?
It's the one on the bottom of the intake pipe that measures the air temp going into the intake. The oem was black plastic but the new one was brass.
05 Malibu: 98K mi
Old 10-07-2006, 11:48 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: What is MAT ?
If the belt chewed it up you may have a wiring problem to.
Ohm out the wires a coulpe of feet back to plugin.
They make rewire plugin kits.
MT
MT
