Old 10-05-2006, 09:25 PM
gribbs gribbs is offline
motor swap
i have a 99 taurus 3.0 12v duratec i think it is and the motor is blown. i wanna do a swap for a sho motor do the motor mounts bolt up and what about the tranny thanks
Old 10-05-2006, 09:56 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: motor swap
Which engine do you have, the 12V (Vulcan) or the Duratech (24V DOHC)? Are you wanting to swap in the SHO V-6 or the SHO V-8?
Assuming the Gen 3 SHO V-8, there are numerous other items you'll need to take into account if you do the swap, such as suspension components to support the added weight, PCM, VAPS power steering, PATS system from the donor programmed to the PCM, and while you have the SHO engine out, you'd want to have the cams welded if you aren't sure that's been done.
By the time you're done, you'd probably be better off to buy a decent used SHO.
-Rod
Old 10-05-2006, 10:06 PM
Re: motor swap
yeah its the vulcan so its not worth doing that at all i justed wanted the motor because i have the body and everything and i am going to be losing money if i just buy a new taurus. i am not going to have anyplace for my old one to go
Old 10-06-2006, 05:54 PM
Millermagic Millermagic is offline
Re: motor swap
If you have the vulcan engine, go to a junkyard and get one if you have to, it would be a shame to waste an otherwise good Taurus on it. Plus, vulcan Taurses are very plentiful in junkyards.
What leads you to believe that it's a blown motor?
- Leather - Transmission Cooler - Gen III Tweeter Sails - Gen III Rocker Covers -
As you walk through the valley of RICE, you shall fear NO V-TEC, for torque is with thee!
