Old 09-04-2002, 09:14 AM
zcmadman's Avatar
zcmadman zcmadman is offline
Send a message via AIM to zcmadman
boxes
ok to do a fiberglass sub tub (the lower half) besides aluminum foil, can i use vaseline? thats what a local audio place told me, but i want to be extra careful, b/c once resin's on, well...its on. how much material wise should a box for 2 mtx 6k 10's and a 4250d amp run me? can i mount the amp on like a wooden platform eventually glassed into the top of the box? any pics of anyones boxes? need advice and suggestions b4 i start. i miss the boom.
Don't let my car fool you, b/c my treasure is in Heaven! My car is just a slice of it.
Old 09-04-2002, 05:49 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Well, I wouldn't use just vaseline. I heard of someone using vaseline with plastic wrap. They coated the surface with vaseline, then layed the plastic wrap on top of it. The vaseline just kinda held the plastic wrap in place. However, I imagine it would be hell to clean up all that greasy schtuff. You should just use tinfoil and tape... that's probably your best bet.
Check out this site really good step by step with pictures:
http://members.iinet.net.au/~nismo/subs.html
Here's a pic of my sub box that I'm working on, although it isn't a "sub tub"...
Old 09-04-2002, 10:13 PM
1990civic's Avatar
1990civic 1990civic is offline
Just Use Aluminum Foil It Works Very Will (remember to over lap the foil)
Old 09-05-2002, 09:25 AM
zcmadman's Avatar
90civic...
dude thats pretty much how i want mine done except i dont want any wires on top like that and im gonna make the top as big as the back carpet area so its all one shape. i might have to make to smaller pieces so i can take it out again though. do you have any more pics on your install?? im doing this primarily to have room for a rear strut bar, but wouldnt the subs sound better at a 45 degree angle? if not that much difference ill just lay them flat. where are you putting your amp(s)? thats gonna end up nice though. man i need a digi cam so i can throw pics up easy like that. too $$
Old 09-05-2002, 03:17 PM
1990civic's Avatar
Thats Just The Box!! I Have Another Piece Of MDF That Goes Over That To Make The Floor, Im Putting A piece Of Plexi-glass To Show Off The Subs, But The Wires Will Be Hidden!!
Old 09-06-2002, 09:34 AM
zcmadman's Avatar
what are you gonna run in the box? b/c id like to make my floor right next to the strut bar w/the subs right under it, but odnt want to make the boox too big for 2 10" mtx 6000's
thanks for the idea on the 2 pieces one floor, one box top. hey check out this civic. hes one of my buds. its really nice
http://members.cardomain.com/johnaug
Old 09-06-2002, 02:41 PM
1990civic's Avatar
well i made the box for two 12" Mtx 6000's
Old 09-06-2002, 09:17 PM
1990civic's Avatar
well here you go zcmadman!! i am getting closer to the end of my project here are some pics of my progress, sorry about the low quality pics i took them at 8 pm!! if u want better pics i can retake tomorrow!!
Fuse Box Passenger Compartment & Power Dist Box nomechanicSENSE Cherokee 1 12-08-2006 11:14 AM
Turning a Sealed Box Into a Vented Box ViperJ Car Audio 11 02-02-2005 02:08 PM
I got 500 bucks for drift box, ultimate cheap drift box! Opinions ? alesserfate Drifting 30 09-14-2004 08:59 PM
