Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 10-05-2006, 03:13 PM
partshunter18 partshunter18 is offline
Question need help
I bought a '95 Plymouth Neon Sport with SOHC 2.0 and about a week later I realized the back up lights didn't work. I replaced the bulbs and they still don't work. What could the problem be? I even checked the fuse and it didn't need to be changed. HELP!!
Old 10-05-2006, 03:21 PM
DentShop DentShop is offline
Re: need help
Your problem sounds to be a very easy thing.
Most older cars may face this issue but for different reasons. If you smell burning plastic or fire, then turn your car off as soon as possible because what happens is the wire gets unplugged and entangled in within the range of the heater causing it to heat up. If this is not the issue, maybe a blown fuse but normally it is the wires.
Check your wires, that is all I can say,
Jason
<Advertising link removed by Moderators>
Old 10-05-2006, 03:34 PM
Thumbs up Re: need help
Thanks I'll try it out.
Old 10-05-2006, 03:37 PM
Re: need help
Alright, take a look at that. If its the back ones like you said, thats new to me. I have had a lot of old cars in my day but still ever since, it was always the front lights. The problem was always the wire or a burnt light, hopefully thats what happened to you, if not let me know and I will figure something out instead of you having to go to a car shop and spending a lot of money.
Hope it helps,
Jason
Old 10-05-2006, 09:13 PM
1thunder 1thunder is offline
Re: need help
the safety neutural switch on the front of the trans controlls the feed to the back up lamps first check for volage at the lamp socket make sure key is on and shifter is in reverse and if you have voltage there and the bulbs are good then the ground terminal in the socket normally break or corrode in the socket this terminal is availlable at the dealer and is replaceable on this car
Old 10-05-2006, 09:15 PM
Re: need help
thanks for the help
