Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 10-05-2006, 03:10 PM
ar455 ar455 is offline
03 Montana Engine Light ON and Codes
I was wondering if anybody had any luck with these engine codes and if anybody can tell me how to trouble shoot these codes. Stored DTC's are P0102, P0141, P0443 and Pending DTC's are P0102, P0141 . Thanks in advance.
Old 10-06-2006, 04:13 PM
GregA's Avatar
GregA GregA is offline
Re: 03 Montana Engine Light ON and Codes
I have a list of what the codes mean at the following page: Diagnostic Test Codes
Looks like three different issues. As for troubleshooting, I would start by checking to connections to all the sensors involved with those codes and go from there. If you don't have a manual, I would get one.
Take Care,
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
Old 10-06-2006, 05:25 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
code P0102 is a mass air flow sensor code.
141 is a 02 sensor heater code
443 is not a code for your van.
Clear codes and see what returns.
Any air intake leaks from filter to tbi?
Any aftermarket air filters.
Are you testing with the air filter or MAF sensor unpluged or air intake hose not on it?
Have you tryed cleaning MAF sensor?
What is the mileage or tune up history?
MT
MT
Old 10-09-2006, 08:55 PM
MT
No air intake leaks from filter to the tbi after close inspection. I did replace the air filter which was very bad and plugged with dirt and sand and oil from getting it rust protected. I replaced the filter with a OEM one. Thinking this was the problem for code P0102. I have not proceeded to test anything yet or try cleaning the MAF and the mileage is about 40K with no tune ups beside the new air filter. I cleared all DTC's with my reader ( INNOVA 1003C ) and the engine light came back on with only one code P0102 again with pending codes P0102, P0141, P0443. Should I try cleaning the MAF sensor which was pretty clean when i looked at last upon Airfilter replacement and I don't understand the testing part of MAF sensor you described.
Thanks in advance
Old 10-10-2006, 08:53 AM
MT-2500's Avatar
AF - Advisor
Thanks in advance
They make a spray on MAF sensor or you can use carb cleaner.
Spray the little wires and resistors in it real good an air dry and try it.
testing requires some electrical equipment and a good scanner.
First test is to check the baro and air flow readings with a scanner.
MT
MT
