Old 10-05-2006, 12:21 PM
bucketabolts bucketabolts is offline
86' no power to cab
I have a 1986 ford f150 with with a carberated 302 and wiring problems. i have no power going to the cab of the truck. no lights, radio, turn signals, fuel pump or igntion switch, no nothin. i have replaced many fuseable links and tested many circuits. the only place i do have power to is the starter solinoid, and when i cross the teminals of the solinoid the engine will crank. but without power to any of the assecories including the fuel pump it will not start or run.
please help me
Thanx, Dylan
Old 10-05-2006, 06:30 PM
mustangmike351c mustangmike351c is offline
Re: 86' no power to cab
make sure the battery and all of the power wires are on the same side and the wire to the starter is all by its self on the other side of the stater solinoid.
Old 10-06-2006, 10:56 AM
ya i made sure thanx thou
Old 10-13-2006, 03:12 PM
rhandwor rhandwor is offline
Did you check the ignition switch it is on the column about 12 to 18 inches down from the key. Probe the large wires coming out for voltage. Their are some links by the solenoid. Their should be some by the starter. Their should be a relay and a ground wire in the right side kick panel. If this checks I will give you some more ideas.
Old 10-16-2006, 10:13 AM
thanx i will have to try that and let u know
