Go Back   Automotive Forums Car Chat > Oldsmobile > Toronado Trofeo
Old 10-05-2006, 12:09 PM
Midnight_Fenrir Midnight_Fenrir is offline
89 blower problem
Well, I have an 89 Trofeo with a VIC and have a pretty serious problem. My blower doesn't turn on.
Orriginally, it would work when I turned the car on, but if I shut it off again, it wouldn't start back up for about 5-6 hours. So I swapped out the blower motor, and now it doesn't start at all. Going on the advice of someone else, I replaced the AC programmer, to no effect.
Recently, I pulled out my multimeter and started running some tests, there is power going to the fan, but only 1.62 volts, as apposed to the 14 it's supposed to have.
I really need to get this solved before winter, I don't want to be driving my El Camino through the snow.. Any help would be greatly appriciated.
Old 10-05-2006, 06:41 PM
Re: 89 blower problem
Err, nevermind, I just found the problem, my blower control module.
Delco 16061602
Old 10-06-2006, 12:32 PM
Alright... back to square one...
I pulled a replacement from a scrap yard and installed it, the power read at 14 volts for about 30 seconds, then went down to 1.52 again, it does this everytime I start the car... and the blower never turns on...
Old 10-06-2006, 12:54 PM
maxwedge maxwedge is offline
A990 racer
A bad blower motor or poor grounds can cause this also.
Old 10-06-2006, 08:25 PM
Well, weather the motor works or not is up in the air, but even a good one won't run on the 1.52 volts that are getting to it...
Are there any specific spots I should check for grounding issues? or do I have to open up alllllll those plastic tubes and tear appart my dash?
Old 10-07-2006, 09:13 PM
Bill V Bill V is offline
Check your BCM for codes. Sounds like there is another issue...
Old 10-08-2006, 12:33 AM
I had run a diagnostic along time ago... there was one code that came up, but I couldn't find anywhere to tell me what it was... GM wouldn't even help me...
I'll run it again and post it here tomorrow...
Old 10-08-2006, 12:15 PM
Ok, here it is.
There were no ECM codes
But there were 2 B111 codes
B552 - History
C553 - Current
Old 10-08-2006, 07:45 PM
DTC B111= High side temp sensor circuit problem (check the data)
DTC B552= Keep alive memory error (normal for batt disconnect)
DTC B553= No such code.
I would go after the high side temp sensor ckt. It might be keeping the system from functioning at all.
Hope this helps...
Old 10-08-2006, 09:44 PM
It is C553, not B553
And the B111 seemed to be a division of codes, not a code itself, it wasn't labeled like the other ones... of course, I don't know much about it, just using logic... (but what about this car is logical?)
But, what can I do about a the temp sensor? I have no idea where that is... much less it's function...
Old 10-10-2006, 01:51 PM
Well, I just pulled the blower motor and hooked it up to my el camino, it started right away, so the motor is good.
