Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 10-05-2006, 11:55 AM
scottp6 scottp6 is offline
Power side-mirror problem
The power side mirror on the passenger side of my 2000 Olds Silh. seems to constantly slowly turn out. I can readjust with the little joystick but it will eventually be turned out again. It doesn't seem to matter if I leave the switch set to either mirror or to the off position. It is only the passenger side that does it. Does this sound like a problem at the switch (joystick type of switch on driver side door) or the mirror.
Any help would be appreciated, it is very annoying.
Thanks
Scott
Old 10-06-2006, 04:27 PM
GregA's Avatar
GregA GregA is offline
Re: Power side-mirror problem
Thanks
Scott
Hi Scott,
This is just a "guess", but I would think that it is probably something wrong in the switch (causing "stray" current to get to the mirror).
I would test this theory by disconnecting the joystick connector for a day or two, once you have the mirrors where you want them. Then plug it back in and see what happens.
There is a picture of the bottom of the switch here.
Take Care,
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
Old 03-12-2008, 09:39 PM
Zackor2 Zackor2 is offline
I have exactly the same problem on my 2000 Sil., strangely it does not drift out while driving, even on long trips - Did you try to disconnect switch? Did you solve the Problem? I was going to dismantel the mirror once it gets warmer.
Old 03-12-2008, 10:04 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Please check the date of the last post in the thread you are replying to and avoid posting in it if it is over 3 month old.
Thread closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Closed Thread
