Old 10-05-2006, 11:27 AM
87Cherokee 87Cherokee is offline
87 Cherokee dies when turning a corner
It runs fine except that it just dies when you turn a corner. The idle is good and it runs smooth. It restarts immediately aftert dying too. Anyone have any suggestions as to what would cause this?
Thanks,
Bill
Old 10-05-2006, 12:25 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 87 Cherokee dies when turning a corner
My first thought is that perhaps something is grounding out. Does it occur in L and R corners, or only one direction? Check for loose/dangling wires under the hood and underneath.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 10-14-2007, 05:37 AM
modesto cherokee modesto cherokee is offline
I have aan 1989 jeep cherokee. I had the same problem. I had heard that it was an engineering problem and had several different fixes. But, after the fuel pump in the gas tank had to be replaced lo and behold.....
THAT PROBLEM disappeared.
Im guessing it was because the fuel pump was weak so it wasn't able to draw gas through which would cause the pressure at it output to drop. A stall would occur. OOOOOHHHH that would piss me off when it happened. So much I hated going around corners. If ya know what I mean.
I hope I was of some help. GOOD LUCK and GOD BLESS.
