Old 10-05-2006, 10:57 AM
jmj_camaro jmj_camaro is offline
I need help!
it all started with my res pulse signal in my 94 camaro. one time when i was coming home from work it just died. all the lights was on its like someone just turned a switch off or something. well i took it to a gm dealer and they "fixed" it and it didnt happen ever sense . until last night when i was driving home again and it did the same thing. all the lights was on it was just like someone turned off a switch. so i checked the fuel pump and the fuel lines but theres plenty of fuel going to the injectors. so i thought it might be that the injectors arent injecting or the spark plugs arent spraking.when i ran a test on the car the only code that showed up was 36 Baro sensor low. I dont know anything when it comes to all these sensors and stuff. please help!
Old 10-05-2006, 11:02 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: I need help!
Have you checked for spark and the condition? The baro low may be a vacuum leak?
Old 10-05-2006, 11:03 AM
Re: I need help!
what do you mean the sprak condition and would a vacum leak cause just to die all the sudden and not start
Old 10-05-2006, 11:07 AM
wrightz28's Avatar
Re: I need help!
No, a quick abrupt death like you describe ussualy points to a ignition/electrical problem.
By condition I mean do you have a strong spark (blueish white) or poor spark (orange)?
Old 10-05-2006, 11:09 AM
Re: I need help!
i havent checked the spark yet ill do that now if the spark is strong then what might it be?
Old 10-05-2006, 11:16 AM
wrightz28's Avatar
Re: I need help!
I'm farily confident that if the problem is present at the time you check, there will be a spark issue. Also, look around the water pump for any signs of coolant leaking!
Old 10-05-2006, 11:18 AM
Re: I need help!
actually i just had a leak. my heater hose sprung and leak and covered everything but i thought i cleaned it up good do you think it messed with my distributer?
Old 10-05-2006, 11:32 AM
wrightz28's Avatar
Re: I need help!
vented optispark + water = no sparky
Old 10-06-2006, 10:48 AM
Re: I need help!
ok i checked my plugs and there is no spark at all but i don't know if it s the distributer because the coil or what ever the thing that sends the spark to the distributer isnt sending a spark either so is there a fuseable link or even a fuse that i over looked . maybe a ground? do i need a new one or can i fix it myself?
Old 10-06-2006, 10:54 AM
wrightz28's Avatar
Re: I need help!
I'm not very familiar with your set up on that year, but I believe it uses a crankshaft sensor? If there is no signal from the sensor the control module will not fire the opti I think
Old 10-06-2006, 01:15 PM
Re: I need help!
hmmm well ill check the coil thing and some other wires and sensers and ill get back to you. thanks for the help
Old 10-06-2006, 01:21 PM
wrightz28's Avatar
Re: I need help!
No problemo!
