Old 10-05-2006, 05:44 AM
mrflint mrflint is offline
Cracked Door Handle
My 2002 Taurus has crack in drivers exterior door handle, flexes at crack when pulled. I was wondering if part can be repaired in place. I was thinking about putting a 1/16 inch line of JB Weld or similar material on backside handle behind crack. Hopefully it will glue it back together or reinforce. As last resort, I can replace it. Any suggestions?
How do you remove the door handle? I've taken car door interior panels off before. Is there a trick to removing the grasping part of the handle or do you need to get inside the door and unbolt it? Thanks
Old 10-05-2006, 09:19 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Cracked Door Handle
I would just replace it before it gets put off too long and weather becomes a factor.
Old 10-05-2006, 12:33 PM
Willyum Willyum is offline
I've used J.B. Weld, sometimes it holds, sometimes it doesn't.
