Go Back   Automotive Forums Car Chat > Chevrolet > Nova
Old 10-04-2006, 08:29 PM
joelcg joelcg is offline
77 nova tranny modulator?
Hi everybody, i just found this forum, and may I say, thank god there are people like ya'll out there. My 77 nova has a 350 turbo tranny in it and when i replaced it i torqued the modular off!! I really messed up. I broke the bracket that holds it on. Is there anyway to fix this or do I have to get a new tranny? HELP!!
Old 10-04-2006, 08:49 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 77 nova tranny modulator?
Let me see if I understand this .. you were tightening the bolt that holds the bracket on, you got a little overzealous and the bolt broke off in the case? No need to panic. You can drill a hole in the dead center of the broken bolt and use a bolt extractor (such as an EZ-Out). The extractor you get won't be that big, since this bolt is 1/4". As you turn the bolt in the loosening direction (left), the extractor will tighten into the screw and pull it out. You have to be careful with this, because if you break the extractor off, you've just compounded your problem.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 10-07-2006, 12:45 PM
Talking Re: 77 nova tranny modulator?
hey thanks man, that helped out alot. I tried it and it worked! Thanks again
