Old 10-04-2006, 07:42 PM
SG007's Avatar
SG007 SG007 is offline
Send a message via AIM to SG007
Help!!! No Brakes!!
When I brought the car home, the brake pedal was very spongy, and the car wouldn't end up stopping until the pedal hit the floor. So, we changed the front pads, rotors and calipers and bled the brakes. After that was done we took it for a test drive and the brakes were WORSE! The pedal would hit the floor, and the car would still be rolling! And to add to the confusion, the BACK brakes, which we didn't even touch, started grinding and sounded like they were dragging, without the pedal being touched...just during normal acceleration. The car isn't losing any fluid....but my master cylinder is the original one the car was built with, could that be the problem? I'm taking it to the garage because I'm completely at a loss for words. I have no idea what this could be! Any tips, boys?
-2000 LS1 Z28-1979 Berlinetta*sold*-1992 RS 25th Anniv. 350*sold*-
Old 10-04-2006, 08:33 PM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
Re: Help!!! No Brakes!!
Sorry i think it's the master cylinder, you said the pedal fell to the floor? Also, umm dragging drum brakes? is the parking brake stuck? If not it's also 'probably' the master cylinder's fault also. Someone back me up, I'm no mechanic.
It kinda sounds like air in the lines but you should replace an old master anyway.
1996 Dodge Ram 1500 5.2L 5spd!!!
1987 Chevy Iroc-Z- -Needs a new cat
1992 Nissan 240sx 5spd- SOLD
Old 10-04-2006, 08:52 PM
SG007's Avatar
parking brake is fine...yeah the drums are dragging, and we didn't even touch them!!!
Old 10-04-2006, 09:07 PM
JustSayGo JustSayGo is offline
Send a message via AIM to JustSayGo Send a message via Skype™ to JustSayGo
Take a look at the back brakes first to find the noise. Brake hardware or lining may have come loose.
Old 10-05-2006, 01:50 AM
goldz28's Avatar
goldz28 goldz28 is offline
When I had my 96 Chevy Pu my master brake booster or cylinder went out. That is why my brake peddle went to the floor. Good luck...
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering
Old 10-05-2006, 02:49 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Does the light on the dash come on?
It could be either the master cylinder (more likely) or the proportioning valve (less, but still, likely).
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 10-05-2006, 07:44 AM
SG007's Avatar
yeah the light comes on when the pedal is pushed to the floor. I hope it's the master cylinder...
Old 10-06-2006, 03:01 AM
Dyno247365's Avatar
I've never heard someone say that before, unless they were really really drunk and then...no not that either.
You knew that buying this car would mean restoring it so it's no big deal. Just get it over with.
