Old 10-04-2006, 06:38 PM
ukfan8's Avatar
ukfan8 ukfan8 is offline
Angry ignition switch
Hello. I need some help with replacing an ignition switch in a 95 trans am. The switch will not turn at all. It will unlock the steering wheel but not turn to start the car or backwards for accessory. I have tried to wiggle the steering wheel and make sure that does not keep it from turning. also I have checked the geer shift to make sure it is in park, the key will not unlock the transmission to change geers. I have done this on a non air bag vehicle but not one with an air bag. Any advice would be appreciated. Thank you.
Old 10-04-2006, 06:43 PM
poormillionaire2 poormillionaire2 is offline
Re: ignition switch
Here's all I got if you need to get to the switch. Have fun and good luck.
http://shbox.com/ignsw/ign_switch_repl.html
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
2009 Kawasaki Ninja 500R
Old 10-04-2006, 08:44 PM
ukfan8's Avatar
Re: ignition switch
I guess maybe I called it the wrong thing. I need to replace the part the key goes in. If you can help me there I would appreciate it.
Old 10-04-2006, 08:49 PM
my99cavy's Avatar
my99cavy my99cavy is offline
Send a message via AIM to my99cavy Send a message via MSN to my99cavy
Re: ignition switch
Here ya go man hope this helps. http://autozone.com/servlet/UiBroker...3d801cf713.jsp
Old 10-04-2006, 08:59 PM
ukfan8's Avatar
Re: ignition
Let me try this one more time. I need to replace the part where you stick the key in the column. Maybe it is just called the ignition. It is not the switch down in the column itself. I need to take off the steering wheel and go down through there I guess. Any help would be appreciated. Thanks to the help I already have received that I asked for on the wrong part. If I would call it the right thing it would probably help. Thanks again for the help.
Old 10-04-2006, 09:04 PM
my99cavy's Avatar
Re: ignition
lol ok I'm pretty sure this is what your looking for (at least I hope) http://autozone.com/servlet/UiBroker...3d801cf727.jsp
Old 10-04-2006, 09:40 PM
ukfan8's Avatar
Re: ignition switch
EXACTLY WHAT I NEEDED. THANK YOU SO MUCH. I REALLY APPRECIATE IT. I KNEW SOMEONE WOULD HAVE WHAT I NEEDED.
Old 10-04-2006, 09:45 PM
my99cavy's Avatar
Re: ignition switch
haha no problem man, I knew I would figure out exactly what you were talking about lol
Old 10-07-2006, 04:37 AM
ukfan8's Avatar
Re: ignition switch
WELL JUST AN UPDATE. THE REASON THE KEY WOULD NOT TURN WAS THE IGNITION SWITCH WAS FROZEN AND LOCKED. THE ROD WOULD NOT SLIDE THE PART IN THE SWITCH TO MAKE CONTACT. THE INSTRUCTIONS IN THIS THREAD WORKED LIKE A CHARM. THANKS AGAIN FOR ALL THE HELP. MY DAUGHTER IS HAPPY AGAIN.... FOR A WHILE.
