Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 10-04-2006, 06:57 PM
daddy0_4 daddy0_4 is offline
93 bravada starter problems ?
I'm in Florida the cars is in cincinnati with our two sons. 93 bravada 4.3 smarttrac about 136,000.this past saturday wouldn't start without jump. took to sams club ( where son works) cleaned corosion off of positive cable, replaced battery (wouldn't take charge). starting ok but volt gauge not going above about 10.(also several times during the previous week when trying to start would just click, after several clicks would finally start.) ok after new battery took to Pep boys,they said alt bad. they replaced it for $200. now still clicking int. took back to P.B. said starter going-$275- they supposedly checked all connections. sorry so winded. any suggestions???
Old 10-04-2006, 09:30 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Cool Re: 93 bravada starter problems ?
Well, sometimes that's how it goes Daddy-O.
To be serious, a bad battery has a short and it will kill your alternator because it's full chat trying to charge up this dead battery everytime the motor starts. Same goes for the starter. Lower voltage creates a high amperage draw and associated heat. The longer one of the brushes stays on one commutater bar (the copper bars on the end of the starter armature), the more heat is generated.
If one of my starters "grunts" one time, I'm checking the alternator and battery cables that day and if the they are good, the battery just gets replaced.
Old 10-05-2006, 05:14 AM
Hi Chris, thanks for the info, but the starter doesn't grunt there is just a click, like a dead battery or a dirty/loose connection. Doesn't anybody "fix" or repair anything anymore instead of replace. The alt probably just needed brushes and the starter is most likely a worn spot on the solenoid. I guess what I'm really asking for is $200 for an alt and $275 for a starter reasonable and does anyone who lives in that area know of some place else to go to. I can do those myself a lot cheaper and it just kills me to pay that much
Old 10-05-2006, 09:40 AM
AF - Advisor
To find a place that rebuilds alternators & starters is getting more difficult these days. To find a place who sells the parts to do the rebuilds is even more difficult.
Another thing is the costs of overhead. Did the $275 alternator include labor to install it?
Old 10-05-2006, 10:12 AM
AF - Advisor
I'm sorry Daddy-O,
I'm starting to see. If they were here, I could be more help.
1993 Oldsmobile Truck Bravada
6 Cylinders 262 W 4.3L CPI STORE SHOPPING LIST
Send a list to your store. ONLINE SHOPPING CART
Search Results: Alternator
Alternator for a
Normal Stock
Item Part
No.
Warranty Core
Value Unit
Price Availability
Store Web
DURALAST
105 Amp DL1345-6-7 LLT $30.00 $89.99
Premium quality reman, some new components
VALUCRAFT
105 Amp 1345-6-7 1 YR $30.00 $69.99
Remanufactured unit
GOLD-DURALAST
105 Amp DLG1345-6-7 LLT $30.00 $118.99
Designed for maximum durability 100 % new
Related Parts
Related Parts are the items we recommend replacing (or inspecting) when you replace your Alternator.
Belt Tensioner for a
Item Part
No.
Warranty Core Value Unit
Price Availability
Store Web
DAYCO Assembly 305201 1 YR $34.99
DAYCO Pulley only 231081 3 MO $29.99
COMPRESSOR_WORKS Pulley only 835975 1 YR $16.99
AC_PARTS 45973 $14.99
GOODYEAR 49208 0 YR
Connector-Alternator for a
Item Part
No.
Price Availability
Store Web
WELLS Not Yet Available
Alternator Repair Kit for a
Item Part
No.
Price Availability
Store Web
VICTORY_LAP GMA-03 $34.99
Alternator cs 121, 130 (Except 130-D)
VICTORY_LAP Can also be used GMA-03S
Voltage Regulator for a
Item Part
No.
Price Availability
Store Web
WELLS VR781 3 MO $29.99
Alternator #1102635
** Must be soldered into place **
(May require alternator bearing when replacing (MORE...)
VICTORY_LAP GMA-03-2S
Battery for a
Item Part
No.
Price Availability
Store Web
DURALAST Optional 78-DL 7 YR $10.00 $59.99
** 700 cold cranking amps (875 cranking amps) **
-> 2 year free replacement <-
DURALAST Optional 75-DL 7 YR $10.00 $59.99
*** 650 cold cranking Amps (810 cranking Amps) ***
VALUCRAFT Optional 75-VL 6 YR $10.00 $45.99
*** 550 cold cranking Amps (685 cranking Amps) ***
-> 1 year free replacement <-
VALUCRAFT Optional 75DT-VL 6 YR $10.00 $54.99
*** 630 cold cranking amps (785 cranking amps) ***
GOLD-DURALAST Optional 75DT-DLG 8 YR $10.00 $74.99
(May require height adapter)
-> 3 year free replacement <-
GOLD-DURALAST Optional 78-DLG 8 YR $10.00 $79.99
** 800 cold cranking Amps (1000 cranking Amps) **
GOLD-DURALAST Optional 34DT-DLG 8 YR $10.00 $69.99
** 800 cold cranking amps (1000 cranking amps) **
GOLD-DURALAST Optional 75-DLG 8 YR $10.00 $69.99
*** 720 cold cranking Amps (900 cranking Amps) ***
Belt for a
Item Part
No.
Warranty Core
Value Unit Price Availability
Store Web
Need More Info. This part may be available for your vehicle, but we need more info before it can be displayed. Click on the link above to find out what info is needed.
This is at one of the major chain type auto parts stores in Cincinnati, PM me if you need more info.
Hopefully the prices shown to you surely included labor.
You can get addresses of other auto parts stores at their websites. I used the 45201 Cincinnati , Ohio zip code.
Old 10-05-2006, 05:27 PM
actually the battery he got at sams club $47, don't know the specs but the guy at sams (per my son) said its the one listed for the car, the alt,$20 to check the system,$56 labor, $89 alt plus tax,shop supplies etc,etc total $199. still has inter. no start-clicking- 2nd diagnosis starter "going" out $275 installed 2-3 hours to do. Is this correct time for labor???
Old 10-05-2006, 07:58 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
The time seems about right, On your Bravada you have to remove the cross member to get the starter out. R&R instructions here: http://www.autozone.com/servlet/UiBr...3d8012a5e6.jsp None of the charges seem unusualy high for a shop but you could have saved a lot by doing it yourself.
As far as finding a shop, go to cartalk.com. they have a list of mechanics that have been recomended by listeners to the show in most areas of the country.
Old 10-06-2006, 01:00 PM
Chris, Eric thanks for the info.I guess they are charging by flat rate.I know it only took about 20 min to replace the alt and the labor was $56 plus $20 to check electrical sys.Like I said before it kills me to have to pay that when I could have done it myself and I realy don't have the extra $$$ to put out for the repairs.
