Go Back   Automotive Forums Car Chat > Racing > Non Specific
Old 10-04-2006, 05:39 PM
Gotian Gotian is offline
Send a message via AIM to Gotian
Gotian's Recall
Well as most of you know there have been recalls for the RX-8 from 2003-2006. The recall was for 4 things:
1) Having trouble starting the car - Solution = bigger alternator and higher powered battery
2) Rough Idle - caused by running too rich and also not enough oil injected into the engine - Solution = A new flash for the ECU to lean out the fuel and help for combustion and to add more oil onto the rotars
3)Cat check - can be damaged because of the two problems above - Solution = Replace cat with a higher temp resistant cat available for the 2007 models
4) Vaccum test on engine - most common on the Auto's - Solution - replace engine.
Apparently they were calling mine the one that escaped. My 8 was made in april, which they stopped making the 06 in May (they were only made for 5 months) and the VIN fell into the numbers that needed the recall. They took mine in cause I called them and told them when I turned it on some mornings it would take a while to start and that I had some rough Idle. So I got the car back today and the ones they needed to do were 1-3. The car felt so much better! It was smoother in traffic, and it felt like it accelerated a bit better (I guess cause combustion's better now) and the MPG improved too, I drove over 80+ miles from when I got it and it had 1/4 tank left and I still have plenty more! Even though these cars have had numerous recalls in the past, I give mazda credit for taking swift care of the problems and giving their clients no hassel and great service, which makes me even happier that I bought from them. So mad props Mazda, mad Props!
"Your car is a wind up toy" - Coworker into american cars
"Why cause it's an import?" - me
"No, cause its a rotary and it spins, d'uh" - coworker
Old 10-04-2006, 05:59 PM
RACER D12's Avatar
RACER D12 RACER D12 is offline
Send a message via AIM to RACER D12
Re: Gotian's Recall
But did you hear about the 5th recall? Due to low tq numbers all rotary's are being replaced with V8s
J/k
Lindsey Boost Enhancer, Blitz EBC, Hot Air Intake, Koni Yellows
Old 10-04-2006, 06:41 PM
2000LS1Z28 2000LS1Z28 is offline
Re: Gotian's Recall
I do like the fact that manufacturers recall cars for whatever problems that they know are common. I think GM has dropped the ball there though, as alot of LS1's have piston slap, and it is a very common problem with the engine due to overboring the cylinder head walls (My previous camaro had piston slap).
My former Evo (Mitsubishi) and Cobra (Ford) both had recalls. The Evo was for something as stupid as a metal plate that misquoted the vehicles weight.
2001 MR2 Spyder
Magnaflow Muffler and OBX CAI.
Old 10-04-2006, 08:21 PM
Re: Gotian's Recall
J/k
That would be very stupid and very rejected by mazdas rx junkies, it would kill the whole concept of the car which is handling.
Anyways I forgot one thing they also did because of the rough idle, they changed the spark plugs to help with it.
Old 10-04-2006, 08:39 PM
-The Stig-'s Avatar
-The Stig- -The Stig- is offline
On Fire!
Send a message via AIM to -The Stig-
Re: Gotian's Recall
You forget that the guys who swap LS1's into the FC Rx-7's still maintain the weight balance, and gain huge amounts of reliability. I still love the 13B-T though... such a great sound.
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
Old 10-04-2006, 11:00 PM
Morphius289's Avatar
Morphius289 Morphius289 is offline
Re: Gotian's Recall
What about the recall to make it a little less ugly?
Black 1997 3000GT
Originally Posted by Igovert500
[01:05] Igovert500: scrwe his method
[01:05] Igovert500: too much crap
[01:06] Igovert500: i just jam a garden hose in there
[01:06] Igovert500: and put it on high flow
[01:06] Igovert500: go the opposite direction too
[01:06] Igovert500: so it clears out more shit
18 and out of debt - member #1
Old 10-05-2006, 01:57 AM
Re: Gotian's Recall
I'd rather swap for the 20B 3 rotar twin turbo 300 rwhp or the 26B (aka the 787b which is the non-turbo used in the lemans) which is the 4 rotar pushing over 700 whp
those guys who swap for LS1's are just muscle car people who wished their cars were faster and looked better. The true RX fans and fanatics mod what they got or swap for another rotary engine.
Old 10-05-2006, 10:50 AM
RACER D12's Avatar
Re: Gotian's Recall
I don’t see how swapping engines makes them any less of a RX fan. I mean I like the 13b-T also but if someone wants to swap in a LS1 into theirs then why not? They are still keeping the best parts of the car... its looks and handling. SCC did a really nice comparison and the LS1 does NOT compromise the handling of the RX7. In fact I think the two engines weigh almost the same. So what’s so wrong with "modding" a car to make it faster? Maybe its not what you would do but whatever. Saying other people aren’t real enthusiast just because they don’t do things your way is ignorant. Hell if the engine goes in my 951 you best believe im going LS1/2 but I guess I am not a real Porsche enthusiast either
Again though I’m not saying the LS1 is better then the Rotary. If I did a RX7 I would stay with a rotary also. But I am just pointing out that there are different ways to the same end of making a fast RX7. And whos way is better or right is just a matter of opinion.
Old 10-05-2006, 11:37 AM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
Re: Gotian's Recall
hm V8 RX-8, not a bad idea.
but yeah V8 FC's tend to be pretty serious cars, I saw one a Formula D last month that was doing really well until it spun.
plus a 20B will cost more to install than a V8 (for FC's).
I'm still swapping the 13b since I like it and I don't need to make outrageous power.
good luck finding a 4 rotor that's not custom built.
There are different fans of the RX-7:
fans of the chassis and fans of the engine. I guess people who swap V8's are the former.
the weight balance has never been perfect with that swap but people have gotten it damn close. Not like it matters when you have 3x as much torque.
And I don't know what you're talking about "gaining reliablilty" since FC's don't have the same problems that FD's do. Many owners have gotten to and beyond 200k on a turbo motor.
RX-7 TII
