Old 09-04-2002, 01:21 AM
91civicDXdude's Avatar
running lean
If my air/fuel ratio is running lean what can i do to correct it short of getting an aftermarket fuel controller?
Old 09-04-2002, 02:23 AM
habib_88's Avatar
habib_88 habib_88 is offline
Lean???
thats sorta odd, most hondas i've seen go rich before anything. Check your fuel system. I'd say maybe replace the fuel filter or espically the 02 sensor.
89 Si #77 and now with 2003 STS winnAr mod!
LadyNRedSi: the integra is a spotless cow
habibswd: i'd sooooo milk a spotless cow
...wow that was a old conversation
Old 09-04-2002, 04:45 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
it might be your fuel pump cause cars that old the fuel pump tends to pump less. get a fuel pressure regulator
Old 09-04-2002, 09:32 AM
well i just dropped a d16z6 with a 90 CRX si computer in my ride. It started flashing oxygen sensor engine code even though i've been using the same oxygen sensor since i bought the car and its been fine. i know its running lean because i drove it hard on the highway for about an hour and when i stopped, the catalytic converter was so hot i was smoking. plus the car runs really hot. Maybe i just need to retard the timing a little even tho i always run 91 octane fuel...
Old 09-04-2002, 12:23 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
which fuel rail & pressure regulator did you use?
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 09-04-2002, 12:45 PM
i used the ones off my 5th gen intake
Old 09-04-2002, 01:04 PM
amy@af's Avatar
are you running the p28 ecu or the CRX Si one?
Old 09-04-2002, 01:46 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Red face
OK...this isn't a flame, but why do peeps run an ECU that isn't made for the engine they have in the car, and then ask questions like "why is my car running poorly?" without providing the history upfront?
I think it would have been nice to say "I have a d16z6 with a pm6 ECU, and it is running lean....any suggestions?" then you can get help a lot quicker.
So when you put in the d16z6 - did you keep your 4th gen intake manifold, etc??
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 09-04-2002, 03:40 PM
darolh darolh is offline
When a cat gets so hot it's smoking it's usually from the car running too RICH from my experience
Old 09-04-2002, 06:28 PM
sorry let me clarify. i do have a pm6 ecu with d16z6. I used the intake manifold from the d16z6
Old 09-04-2002, 09:34 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
Cars run hotter when lean.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
