Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-04-2006, 03:45 PM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Swapping ECU's
I have a friend trying to sell me an EPROM ECU to go in my car...
They are both '91 Talons... but his is an AWD ATX
mine is a FWD 5Spd... will it work?
b/c $150 isn't a bad price for a EPROM ECU, but it is a lot for a circuit board I can't use...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 10-04-2006, 09:36 PM
nofear39427 nofear39427 is offline
Send a message via Yahoo to nofear39427
Re: Swapping ECU's
Well I got too searching about on this topic on google and the way it looks is that the Ecu might work but the cars would have to be the same year model.I am a little skeetchy on the whole awd to fwd ecu swap because it seems that the awd would have a different code or something.But hey it never hurts to try..or does it?
Old 10-04-2006, 09:43 PM
Re: Swapping ECU's
sorry to post twice my computer is acting up and i didnt finish.
Here is something else that may be helpful to you.
The alternative, a non-EPROM ECU, does not have an EPROM. Instead, the program is stored inside the microcontroller itself (technically, in embedded EPROM memory that is part of the microcontroller). This makes it hard to change the ECU programming, because the microcontroller needs to be replaced. These are difficult to get, and require special programming tools that are equally difficult to find.
GooD LucK MaN
Old 10-05-2006, 02:29 AM
Dsm89 Dsm89 is offline
Send a message via AIM to Dsm89
Re: Swapping ECU's
so the ecu is made for a awd an yours isnt ummmm....... it depends on motor size really
whats up
Old 10-05-2006, 07:31 AM
Mikelb's Avatar
Re: Swapping ECU's
GooD LucK MaN
EPROMS are socketed (Right?)... so I could drop in the chip to run DSMLink
Old 10-05-2006, 08:55 AM
Re: Swapping ECU's
If your talking abour reprogramming the ecu .good luck like i said last night it is very difficult and you can screw the ecu up.
Old 10-05-2006, 09:42 AM
Mikelb's Avatar
Re: Swapping ECU's
no, DSMLink is a piggyback fuel controller/datalogger...
it allows you to tune the car...
Old 10-05-2006, 10:05 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Swapping ECU's
Who told you that??. 91-94 turbo ecu's are interchangeable.
DSM geek
Old 10-05-2006, 10:29 AM
Mikelb's Avatar
Re: Swapping ECU's
you can go to the DSMLink website...
it helps you monitor things so you can tune better... but you have to have a socketed ECU, to put their chip in for the default values
and I wasn't certain a/b swapping the ECU's, that's why I asked...
P.S.- Sorry, I said it was a piggyback fuel computer... I was incorrect.. I mean a datalogger... I was confusing it with my AFC...
Old 10-05-2006, 12:23 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Re: Swapping ECU's
lol any eprom, from 91-94 will work in your car just fine... the FWD computers have a speed limiter at 137mph... the AWD ones have no speed limiter... your choice. i have a AWD computer in my FWD running just fine! and DSMlink is NOT a piggyback. it doesnt over-ride or change anything to "Trick" the computer... it changes the computer. FYI. ok, thats all.
Old 10-05-2006, 01:19 PM
Mikelb's Avatar
Re: Swapping ECU's
OK, sounds good a/b the ECU... yeah, I know what the DSMLink does... I'm just stumbling over my words today... I was up til 1 last night working on the Talon... I'm very sleep deprived (I had to write this paragraph a/b 3 times, b/c of all the misspellings/typos)
