Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 10-04-2006, 02:53 PM
mitllek mitllek is offline
olds 88 pobs.
I have a 94 olds 88 royale 3800 vin L engine.When i start it, it idles really rough and makes sort of a constant "whoosing" noise like it's sucking an excesive amount of air through the throttle body. it clears up after about 2 minutes but if i jerk the throttle it clears up right away. i get a mass air flow dtc and i replaced the maf to no avail.....any suggestions?.thanks in advance
Old 10-04-2006, 04:34 PM
acidcrashdburnd's Avatar
acidcrashdburnd acidcrashdburnd is offline
Send a message via AIM to acidcrashdburnd
Re: olds 88 pobs.
the gasket around the throttle body?
1993 Olds 88 112k and counting 81 mile a day daily driver.
2005 Grand Prix 47k weekend car.
Old 10-04-2006, 04:38 PM
maxwedge maxwedge is offline
A990 racer
Re: olds 88 pobs.
Welcome to AF. Check the pcv valve o rings, also check for vacuum leaks around the throttle body.
Old 10-05-2006, 07:48 AM
Re: olds 88 pobs.
i checked all the gaskets and there are no air leaks that i can tell. could it possibly be the egr? cause it does pipe into the throttle body.......
Old 10-05-2006, 01:58 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Re: olds 88 pobs.
Try cleaning: http://www.lesabret.com/phpBB/viewtopic.php?t=4054
I bet your IAC valve is clogged up pretty bad.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
