Old 10-04-2006, 02:15 PM
phil a phil a is offline
97 S10 oxygen sensor code on. accurate?
Some times the codes are not always right,,
the sensor is most likely bad?
for sure bad?
or search for a vacuum leak?
Old 10-04-2006, 05:17 PM
sreve sreve is offline
Re: 97 S10 oxygen sensor code on. accurate?
whats the code?
Old 10-04-2006, 09:22 PM
99avenger2.5 99avenger2.5 is offline
9 out of 10 times it is going to be the sensor, but if you want to find out for sure you can swith one of the sensors. If it is a V6 it will have 4 O2 sensors. if the code changes it is the O2 sensor.
Old 10-05-2006, 09:37 AM
sorry; codes are p 146 and p147
Old 10-14-2006, 11:13 PM
16th hippy 16th hippy is offline
if i'm not mistaken, those are the codes for the catalyst monitor(after cat o2 sensor). usually when it sets a code of no activity(P0146), the sensor is bad, same if it sets a code for heater circuit malf.(P0147). If the wiring leading up to the sensor looks ok, then replace the sensor.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
Old 10-17-2006, 06:09 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
dont switch the o2s around, they are very spicific as to where they go, they do not all work the same, if you put one in the wrong spot you can fry the moter
