Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-04-2006, 12:39 PM
Stites Stites is offline
How the #@%*&!!!
Hey y'all,
Just recently bought a 2000 Passport LX. More power than I expected out of it(Believe me, I'm getting in this thing after letting go of a 2000 Trans Am WS6), and it's more suited to our lifestyle. I just have one small question... how the #@%*& do you flip up the rear seats?!?!?!?! There's these two little straps on the sides coming out from under the seats, but I'm afraid if I pull any harder on them, I'll tear them out and really be screwed. HELP!!!
98% of fatal car crashes in the southern Appalachians begin with "Hey y'all, watch this!"
Old 10-04-2006, 12:40 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: How the #@%*&!!!
Pull them both at the sametime up. This is release the seat and flip it up at the sametime.
-Ryan
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 10-04-2006, 05:17 PM
Isuzukid2 Isuzukid2 is offline
I had the same problem with my 99 Rodeo. I took a metal bar (or wrench) and inserted it into the loop and pulled on it really hard. For some reason, the latches seem to jam up on it making it hard to pull with your bare hands. Give it a try, I'm pretty sure you have the same problem I didn.
Old 10-04-2006, 10:50 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
dont pull it straight up pull up and to the door you are standing in if that dont work you will need to use the metal bar method that Isuzukid2 described
normally when they get stuck like that it is because there is something under the seat
Old 10-05-2006, 11:07 AM
surferfletch surferfletch is offline
Put pressure toward the back of the cushion, then pull. Helps me.
Old 10-05-2006, 10:59 PM
Stites0518 Stites0518 is offline
I figured it out. Y'all are gonna think I'm we-todd-t-tod-de-tod-did, but I was pulling the wrong strap. There was a couple of straps hanging out from underneath the outer sides of the seats, apparently the ones that hold the backs in place. After rooting around in there where the seat belts come out, I finally found the release straps, pulled them, and the seats work like a charm.
By the way, I've looked at the rear axle from behind, and it looks strikingly similar to a Dana 44. Anyone know for sure what it is?
Old 10-05-2006, 11:11 PM
D44 it is! You may have trouble convincing many parts guys, but it is. Wish I had it on my Jeep. It's got the 35 with 3.07 gears.
Old 10-05-2006, 11:20 PM
AWESOME. One less thing to worry about.
I hear ya on the D35, man. I have an '85 CJ7 with the AMC 20... better than the D35, but mine's gonna need trussing before it's all said and done.
Old 10-05-2006, 11:23 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Actually a modified D44, but yes it is one.
The rodeo/passport/amigo version apparently has a much beefier pinion gear. Also it has a toothed ring next to the ring gear for the ABS sensor.
Surprisingly I didnt get any argument from napa with the last cover gasket I bought (unlike the first time). Had a bit of trouble finding the right part number though, finally remembered to look at a mid 70's waggy front axle.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 10-23-2006, 06:40 PM
So uhh, this modified D44... What's modified about it? Could I still order a TrueTrac limited-slip differential for a regular handy-dandy D44 and it actually fit in this one?
