Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 10-04-2006, 11:22 AM
bjboertje's Avatar
bjboertje bjboertje is offline
hood latch
my hood won't latch all the way down. it is currently only latching to the secondary one that you lift after you pop the hood. it wants to lift up at 60+ mph. anyone else have this problem or know an easy way to fix it? dealer says 60 bucks for a new one! i may just have to find one in a junkyard.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 10-04-2006, 11:38 AM
Markb873 Markb873 is offline
Re: hood latch
Just replace it junk/dealer whatever. Don't try to fix it, it just sucks having a hood hit your windshield.
Old 10-04-2006, 11:42 AM
alphalanos alphalanos is offline
Re: hood latch
check to make sure your hood release lever inside the car isnt sticking. Mine did that and I had to push the lever back into place after pulling it.
96 EJ6. Future home of boosted B18C1.
Old 10-04-2006, 07:14 PM
buttnekked buttnekked is offline
Re: hood latch
oil latch and check rubber stoppers that support closed hood. All else fails junk yard or ebay would be your best bet.
Old 10-04-2006, 10:02 PM
Re: hood latch
Mine has done that for years. i see i'm not the only one.
Old 10-05-2006, 11:10 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: hood latch
get it fixed before it flies up and you end up in an accident.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 10-05-2006, 02:21 PM
KimMG KimMG is offline
AF - Advisor
Re: hood latch
Markb873-
Please repair it soon. It is no fun being on a freeway with a car when the hood goes flying. I saw someone's hood fly up and smack the windshield, then tear partially off and drag on the side of the car. The driver must have been startled because he then drove across several lanes on the freeway without regard to other motorists. What would have been a simple nut and bolt repair that probably would have cost less than $100- and taken a couple of hours is now probably ten times. He will have to replace the hood, possibly a fender, hood hinges, windshield and trim, might of had some damage to the area where the roof meets the windshield.
bjboertje-
Don't forget to inspect the pin (the part that is connected to the hood) to make sure it is not damaged or worn. If it does not enough of a shoulder on it, it will not be able to grip or lock into the latch. Make sure all the parts are clean and lubricated so they can move easily, make sure the return spring is doing its job.
Old 10-05-2006, 03:57 PM
bjboertje's Avatar
Re: hood latch
took it to a dealer to look at it after i lubed it up and all that. they said there is a plastic part on the release cable that is broken. the hood is latched for now, until i find another cable.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
