Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 10-04-2006, 10:59 AM
MrBB's Avatar
MrBB MrBB is offline
Pump Gas or Race Gas?
I would like to find out if a 347 motor running 11.2 compression would run pump gas, race gas, or a mixture. Would premium gas with a can of octane booster do the job, or would a mixture of racing fuel and premium work? What is a good resource to use concerning engine compression and fuel requirements?
Any help is greatly appreciated!
Thanks!
MrBB
Old 10-04-2006, 01:13 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: Pump Gas or Race Gas?
Depends on the heads, cam, timing, ect.
1969 Cougar
357w & TKO - 475hp
Old 10-04-2006, 01:51 PM
MrBB's Avatar
This is what I know about it.
Stock roller block
Eagle forged crank
Eagle forged H-beams
J&E forged pistons
Probe girdle
Clevite bearings
Plasma-moly file fit rings
Blueprinted Melling HV oil pump
ARP oil pump d/s, clearanced correctly
ARP main studs
ARP rod bolts
ARP Head Studs
TFS Track Heat Twisted Wedge heads, ported, flow~282/[email protected], springs upgraded to .600" lift.
Comp roller rockers
TFS hardened pushrods
TFS #2 cam, degree'd in correctly
Old 10-06-2006, 05:30 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
My best friend runs a 351w at 11.2 on pump gas, timing is turned down a bit, but that thing has tons of torque down low. Hell, I could not help but spin the tires when I was driving it.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 10-06-2006, 08:20 AM
MrBB's Avatar
Thanks for the info!
Old 10-06-2006, 08:59 AM
SkylineUSA's Avatar
No worries, killer combo you are building!
