Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 10-04-2006, 12:25 AM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
Exclamation d16a6 engine rebuild
alright heres the deal i have two d16a6's and i need to make a working motor out of them. if one of the rods broke would i still be able to use the block? its not messed up (no cracks anywhere, some nicks inside)but im worried that it wouldnt have the same compression and would just blow again once i put it back together. i dont kno what would cause the rod to break in the first place. ill get some pics up soon of what they look like. im pullin the hatchs motor on saturday but ive already begun breaking down my old crx one. the heads on both of them look fine since the bottom end was what went out but could something in the head have caused the problem?
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
Old 10-04-2006, 12:03 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: d16a6 engine rebuild
bring the block to a machine shop and see what they can do about the small chips in the cylinder bore...you might just have to bore it .20" over and get a larger set of pistons...Nothing in the head should have caused the bottom end to go out....nothing that i can think of anyway
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 10-06-2006, 11:58 AM
would it be possible to use the carriage around the crank from a z6 engine and put it into the a6? i found a z6 bottom end and tranny at the junkyard so im thinkin i might just find a z6 head and put a sohc vtec in but im not sure yet cuz i have all these a6 parts layin around.
is the z6 tranny better than the a6 one?
Old 10-06-2006, 02:31 PM
Schister66's Avatar
AF -Advisor
^^ that i dont know...post this on Honda-tech and you'll get more responses...the Honda section on AF has kind of died in the last year
